Results 1 to 7 of 7
    learning2's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default Is there a way to clean up the "my apps" list?
    Sorry if this is answered somewhere -- searching on "my apps" is too vague.
    You know how when you get a new phone and you load, say, six clock widgets, play with them, pick one you like, then uninstall the other five?
    I've had my phone for a couple years now, and I've done that several times (tried browsers, keyboards, etc.) The result is that the "my apps" list on my Google Play account is cluttered with all sorts of stuff that I don't ever want to reinstall again. Is there any way to delete things I don't want from that list, to make it more readable? (either from the phone or the website is fine.)
    Thanks!
  2. #2
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    ROM
    CLΞΛNЯOM
    Default Re: Is there a way to clean up the "my apps" list?
    answer
    Permanently removing uninstalled apps:
    At this time, there is no way to permanently delete or remove apps from the Google Play website (My Orders/My Android Apps) or from the Google Play Store app (My Apps) that you’ve previously downloaded but have since uninstalled.
    Uninstalling apps using the Google Play website:
    Android apps may only be uninstalled from the device itself - there is no way to remotely uninstall items from play.Google.com
    I agree there should be a filter for showing which apps you have downloaded or no longer need. The only thing you could possibly do is create a new Gmail account and link it to the Play Store.
    Thanked by:
    learning2's Avatar
    Posts
    Global Posts
    41 Global Posts
    Default Thanks!
    Not the answer I wanted, obviously. But thanks for looking it up for me.
  4. #4
    cyberdalek's Avatar
    Posts
    Global Posts
    366 Global Posts
    ROM
    Affinity/Franco
    Default
    I would love to be able to delete those apps. It frustrating searching through all those apps to reinstall after you flash a new ROM and auto restore doesn't work.
    Sent from my Galaxy Nexus
    “There’s always something to look at if you open your eyes!”
    -The Doctor-
  5. #5
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Quote Originally Posted by Xfanatic View Post
    Before you flash the ROM, back up all your apps with a program like Astro (it creates apk files). After you flash the ROM, rstore the apk files with an apk installer app (there are a few free ones - they all work the same). You can copy the apk files to your computer to always have a local backup of the apps you need.
  6. #6
    cyberdalek's Avatar
    Posts
    Global Posts
    366 Global Posts
    ROM
    Affinity/Franco
    Default
    Quote Originally Posted by Rukbat View Post
    I recently started using TiBU that makes things a whole lot easier but I remember pre-TiBU
    -The Doctor-
  7. #7
    devinder's Avatar
    Posts
    Global Posts
    2 Global Posts
    I have recently reviewed a pretty new Android clean up apps, It is working for me, It might help so sharing it here,
