Results 1 to 3 of 3
    Default When phone connected to wifi, file sharing with pc?
    Just wondering if you can file share when your connected to the same wifi as your pc. This way I can transfer photos instead of using the usb cord.
  2. #2
    Default Astro
    Use the ASTRO file manager with the additional ASTRO SMB Module, both available from the market. You can browse all your windows shares by hitting the network icon by moving the icon bar all the way to the right.
  3. #3
    SeeK's Avatar
    Posts
    Global Posts
    296 Global Posts
    ROM
    InsertCoin 1.1.1
    Default
    I use EStrong File Explorer, which I'm quite happy with. I've heard good things about ASTRO though, so I'd say it's a matter of preference.
