Results 1 to 2 of 2
- 08-31-2012, 09:22 AM
Thread Author #1
help? Maybe silly?
I have an LG Spectrum phone.
I have way to many pictures and documents stored on my sd card.
Can I take the card out of my phone and place it in my laptop or desktop and transfer all pictures and documents to either one then delete them from my sd card and then put it back into my phone?
Will it mess up anything on the card to where I would not be able to use my phone?
Thank you all for any input?:-) - 08-31-2012, 10:58 AM #2
Re: help? Maybe silly?
You can. I would just connect via USB. The dialog box will pop up asking to view files etc... find the files copy to your desktop and then you can delete the files from your phone. If you don't have a file viewer on your phone, Linda file manager is a good one.
Privacy is overrated :P
Reply
