Results 1 to 5 of 5
    Default Gnex won't complete boot: how can I save images?
    So my gnex (verizon, completely stock) has crapped out: when booting, the word "google" that is first displayed flickers a bit, then the startup animation flickers, then it restarts (having never completed the boot). I _can_ get the bootloader menu to display. When I plug the USB into a computer, it says "device driver failed to load".
    My question: is there any way to save data (pictures in particular) from this phone?
    I'm returning it to verizon in a couple days and it'd be sweet if I could grab the pics of my pet rats first
    thanks!
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Gnex won't complete boot: how can I save images?
    If you can't boot it up, I think you are SOL.
    I figured. thanks for the post, though!
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default
    No problem. Does the device have an SD slot? If so, make sure to set your pics up to go to it in the future and next time you'll be able to save them.
    Sent from my DROID X2 using Android Central Forums
  5. #5
    to avoid such things in future enable instant upload in google+. as soon as the pics/videos are taken it upload to google+ and keep it private. I enabled it the hard way after losing some pictures.
