Results 1 to 4 of 4
    Default Navagating on large body of water
    Does anybody know if I can use the Navigation on my phone to go from one point on water to another or will the phone route me to the nearest road to get to my end point?
  2. #2
    Default Re: Navagating on large body of water
    There's no marine navigation in Google maps that I know of (so it will try to use roads).
    But there are several marine navigation apps available in the Play Store.
  3. #3
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,234 Global Posts
    ROM
    NOS M7 Sense 5.0
    I use the Navionics which I downloaded from the play store on the Great Lakes and it's just as good as any marine chart plotter I've used. They have different versions for different areas of the world.
  4. #4
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,234 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    Screen shot
    Attached Thumbnails Attached Thumbnails Navagating on large body of water-uploadfromtaptalk1347040770628.jpg
