Results 1 to 4 of 4
- 09-08-2012, 12:20 AM
Thread Author #1
Lost Keypad Sound in ICS Phone Dialer in Razr
I'm not sure if this is "device specific" or not so I hope it's ok to post here.
Lost my "Touch Sounds" as well.
Dial pad touch tone is ticked under System Settings.
And yes, the phone has been rebooted (turned on
and off) several times. I've also wiped the cache
and booted in Safe Mode. I uninstalled all the apps
that were installed around the time of the problem.
And before you ask, yes, the volume is up AND,
the dialer tones have worked since upgrading to ICS.
The last thing I want to do is reformat. Can anyone
help?
Thanks,
Monica - 09-10-2012, 08:50 AM #2
Re: Lost Keypad Sound in ICS Phone Dialer in Razr
Have you tried clearing Data for the dialer? Not sure what that would do or what settings you would have to redo, but, just a thought.
- 09-10-2012, 06:56 PM #3
That's odd. When I lose the touchtone sounds (which is a known issue with the Razr and Razr Maxx--can't remember if this happened before ICS), I can usually "wake up" all sounds by going to Settings->Sounds->Ringtones and just selecting a ringtone to hear it play. But it sounds like you've tried that, correct?
- 09-11-2012, 01:03 AM #4
Reply
