junkman50
3
When I use gmail (version 2.3.6), I can't send the same email to multiple contacts at the same time. I have no way to access my contacts (people) and choose more than one contact without having to keep adding one contact at a time. I want to be able to choose several contacts and add them at the same time. Gmail help said click on the gmail icon in the upper left hand corner, but there is none. What do I need to do?
Devinator
Sūpā Saiya-jin Fō
Jul 27, 2011
3,000
147
What way are you trying to add them? In the two portion of an email, if you just start typing there name, suggestions should pop up, and, you can add one, and it will put a comma at the end. Then you can start typing another person to email and add them in the same fashion.
Chelsea rae
