Results 1 to 4 of 4
    Default Connection to Oracle Database
    Dears,
    We are developing an Android application will connect to Oracle DB.
    I have problem with JDBC library dependencies.
    I always get (java.lang.ClassNotFoundException: oracle.jdbc.OracleDriver) error, this happened when the Class.forName ("oracle.jdbc.OracleDriver") didn't find the JDBC library.
    At my case I double checked that my ojdbc6.jar library is existed correctly at build path.
    Is there any farther configuration I've missed ?
    Regarding libraries dependencies, is there any difference at development between J2SE and Android application ?
    IDE: Eclipse SDK 4.2 with Android
    Android target platform: 2.3.3
    Thanks and best regards,
    Tiny
  2. #2
    Default Re: Connection to Oracle Database
    do you have the jar file under the "lib" directory of your eclipse android project?
    There's no "lib" folder at eclipse Android project.
    Instead there's "libs" folder, I added the JDBC library inside this folder.
    At other hand there's another library at "libs" folder, it's "android-support-v4.jar", thus I suppose that's "libs" is the correct place to add my libraries in.
    Should I create "lib" folder manually ?
  4. #4
    Forgive me for my typo. Yes, it is "libs". So it doesn't work there? Because I have used libraries like this. Sometimes cleaning the project and all its dependency projects helps. But I'm sure you already did that.
  1. Please Help - Can not connect to my PC
    By alextodd16 in forum Motorola Droid
    Last Post: 05-08-2013, 07:52 AM
  2. Cannot connect to internet?
    By largeselection in forum Motorola Droid
    Last Post: 04-24-2013, 09:36 AM
  3. difficulty connecting to home wireless network
    By cornstarch in forum Motorola Droid
    Last Post: 07-16-2010, 09:36 PM
  4. Unable to Connect to Exchange on WiFi
    By sirmichael in forum HTC Droid Eris
    Last Post: 07-15-2010, 04:49 PM
  5. Replies: 2
    Last Post: 12-03-2009, 09:07 PM
