1. dchick's Avatar
    Hello, I would like information on how to use my Samsung Stratosphere 4g lte cell phone as an MP3 device? My car has a standard usb port and I can use a memory stick/I-pod for playing music but the usb doesn't recognize my phone as a mass storage devise, I was told I might need a data cable, not just the charging cable? Verizon personnel was No help!! I hope you can be
    Thank you
    09-12-2012 05:45 PM
  2. still1's Avatar
    I think you can use the charging cable to connect as USB but you will have to enable USB mass storage in your phone to make your car it as USB.
    Did you do that. You might also need an app to make this work and it depends on your car.
    09-12-2012 07:53 PM
  3. prissysox's Avatar
    Does your car stereo have an AV jack or blue tooth? These would be simple ways to use phone as mp3.
    Sent from my HTC One X using Android Central Forums
    09-12-2012 08:01 PM
  4. Devinator's Avatar
    You can use the charging cable for USB. I do so with several devices.
    09-13-2012 09:56 AM
  5. jean15paul's Avatar
    I don't know if this applies to your phone ... the only phone I know that it applies to is the Galaxy Nexus. But... Some newer devices that don't have SD card also don't support the device being recognized as mass storage. They use MTP protocol which your stereo probably can't recognize.
    Like I said, I don't know if this applies to you (probably not). But it's the thing that came to my mind.
    09-13-2012 01:24 PM
  1. Replies: 39
    Last Post: 12-30-2013, 03:15 PM
  2. data allotment to use google voice?
    By js6218 in forum AT&T Inspire 4G
    Last Post: 01-18-2013, 11:50 AM
  3. Using a Tablet as an All-in-One Car System
    By Cadillac.Cowboy in forum Misc. Android Tablets
    Last Post: 10-06-2011, 06:33 PM
  4. If you buy outright at Verizon, do you need a data plan?
    By BlackPrince310 in forum Motorola Xoom
    Last Post: 02-22-2011, 02:04 PM
  5. Do I need a Gmail account to use the Evo?
    By PurpleGuitar in forum HTC EVO 4G
    Last Post: 06-03-2010, 01:21 PM
