Results 1 to 5 of 5
    Default Stuck GPS signal
    Second time in two days the GPS active icon in the status bar was stuck on. Today it was on for over three hours before I just powered off the phone to get rid of it. I looked in running services but couldn't tell if anything was wrong.
    Any ideas? Thanks.
  2. #2
    SeeK's Avatar
    Posts
    Global Posts
    296 Global Posts
    ROM
    InsertCoin 1.1.1
    Default
    Can you not use the Power Control widget to turn the GPS off completely?
  3. #3
    Default
    Yeah I've had this happen twice. First time I restarted the phone, second time I turned GPS off.
  4. #4
    SeeK's Avatar
    Posts
    Global Posts
    296 Global Posts
    ROM
    InsertCoin 1.1.1
    Default
    Are you running any apps that might use the GPS a lot? What phone do you have, by the way?
    If it's just starting the GPS on its own when you boot the phone, something might be wrong.
  5. #5
    Default
    (Oh right, this is a general forum, I got here via "new thread" search.)
    EVO w/2.1 -- it happened after quitting Google Maps ... the GPS icon will not quit even after the app is definitely exited properly. Doesn't happen usually, only a couple times so far.
