11-08-2015 09:10 PM
29 12
tools
  1. ndlkid13's Avatar
    I have a Samsung Micro Sd Card SD HC 8Gb. I've had it in my phone (Htc Evo 4g) for a while now but one day it said I have no Sd Card inside. I took out the battery reinserted it inside but no luck. Then I checked on a computer and when I click on Removable Disk, its says, "Please insert a disk into Removable Disk (E.
    I have also tried this method (make use of. com /tag/how-to-recover-data-from-a-corrupt-memory-card-or-usb-drive/) but when I enter Chkdsk e: /r it says, "cannot open volume for direct access." Please help, I have many stuff on the Sd Card and I don't wanna format it and lose all my data. Any help?
    09-18-2012 12:20 AM
  2. B. Diddy's Avatar
    Do you mean you took out the SD Card and then reinserted it, or was it actually the battery you took out and reinserted? It's possible that the SD card may have become unseated, perhaps if the phone dropped--if you haven't tried already, take the card out and then reinsert it, making sure it clicks into place.
    09-18-2012 12:33 AM
  3. cyanogen-man's Avatar
    yea y would you take out the battery? Go to settings storage and see if it says mount SD card?? If so release the SD card then push it back in and press mount if it didn't do it already and if not you mite have a burnt SD card it can happen if you rooted and tweaked the SD speed there set there for a reason. I hope we were of help
    INSPIRE AOKP ICE COLD SANDWICH ROM
    09-18-2012 01:29 AM
  4. ndlkid13's Avatar
    I have to take out the battery in order to get to the sd card. My phone didnt read the sd card and neither did my computer.
    ---------- Post Merged at 03:23 AM ---------- Previous Post was at 03:21 AM ----------
    My phones not rooted
    09-18-2012 02:23 AM
  5. carracerz14's Avatar
    If it isn't being read on either device it is likely that it is shot. These things happen sometimes, you can format it and see if it is still Usable, and if it is you may be able to recover some of the files using a recovery program on your computer.
    Sucks when these things happen. So far I've been lucky and haven't had this happen to me but I know of friends who this has happened to.
    Sent from my RAZR MAXXIMUS
    09-18-2012 02:25 AM
  6. B. Diddy's Avatar
    Man, I hate phone makers who force you to take the battery out in order to access the SD. Thank God they've realized now that this is utterly stupid.
    09-18-2012 02:30 AM
  7. ndlkid13's Avatar
    The micro sd card is not showing up anywhere. Not on my computer nor my phone, as if there was nothing there.
    Fred Houck likes this.
    09-18-2012 03:13 AM
  8. carracerz14's Avatar
    You're gonna have to format it and hope that it will work after and you won't have to buy a new one. Do a Google search for some type of file recovery program and hopefully you can recover some stuff
    09-18-2012 11:38 AM
  9. larabar's Avatar
    how do you format when it's not being recognized? i know how to format an sd card when it shows up under removable disks on a computer, but not when it's not recognized by any device.
    Moayyad Aboud likes this.
    04-01-2013 05:33 PM
  10. jamaal91's Avatar
    having the same problem. need help
    04-11-2013 09:43 PM
  11. markwilliams279's Avatar
    Check the memory card for any type of crack and metal part of the card is ok or not. Because of this your memory card can not be detected with the mobile and computer as well.
    04-11-2013 10:46 PM
  12. Mohammed Alaa's Avatar
    i have the same problem that the SD card cant be recognized neither on the phone nor the computer . so how can i forrmat or recover it ????
    10-21-2013 04:50 PM
  13. Luckysabir Sabir's Avatar
    11-02-2013 01:13 AM
  14. B. Diddy's Avatar
    If your SD card can't even be recognized by your computer, then it's probably unsalvageable. You could try it on someone else's computer just to be sure, but you're better off getting a new card. If there was important data on the faulty SD card, then you could look for some local data recovery service to see what they can do.
    11-02-2013 09:26 AM
  15. Fred Houck's Avatar
    What do I do with a shot sd card and want to format it? I dont know of a formatting option
    05-10-2014 02:33 PM
  16. carracerz14's Avatar
    If its shot and isn't recognized by your PC then I don't know if there will be a way for you to format it.
    Sent from my Nexus 5 using Tapatalk
    05-10-2014 02:39 PM
  17. Vsweety's Avatar
    If it's a brandnew SD card you can try to exchange it for a working one from the place that you bought it.
    If that doesn't work: chuck it.
    Last ditch try: connect an SD card reader to your PC or Mac, insert the card and see if the PC/Mac recognizes it and let's you format it.
    If not: chuck the card.
    05-11-2014 06:20 AM
  18. AMITHA BANDARA's Avatar
    I have 4gb micro sd card in my phone.yesterday i open to sd card but its said no memory card.how to get my photos and document
    05-19-2014 11:33 PM
  19. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Storage. Do you see your external SD card listed there? If so, Unmount the card, remove it, and insert it into your computer. Can the computer read it? If not, it may be irreversibly corrupted, although you might be able to find some programs or services that can try to recover data.
    If the computer can read it, backup all the data on the card to your computer, then reformat the card. Transfer the backed up data back to the card, reinsert it into your phone, and see if it works.
    05-20-2014 01:07 AM
  20. Latino Boy's Avatar
    Never knew about this problem till it happened to me now it's been already 4 days I've tried 3 PC-S. 5 phones non of them can see my micro SD card first it worked perfectly then I took it out without pushing the eject button on my phone in settings and next thing I saw was that I have no SD card it's painful because all the pix of my son since he got born and all cool music I've been getting together almost 4 year if not more they all are gone ..... I've cleaned the surface still no progress not sure about the reader but my computes comes with built-in SD card reader so I think it's much the same ..... can't format it because my PC doesn't see it doesn't make the sound of seeing something well hopeless situation if you guys can help me I would be so happy thnx.
    05-24-2014 04:20 AM
  21. Rukbat's Avatar
    Download PhotoRec - CGSecurity Burn it to a CD (there are full instructions on the site, this is a tl;dr version). Boot the computer using the CD. Connect the card to the computer (using a card reader, not the phone). Even if the file format of the card is corrupt, PhotoRec looks for groups of bytes that look like files, not for file listings in the directory, so it makes no difference. If the files are still on the card, PhotoRec will find them and save them to the computer. If PhotoRec can't find them the chances are that the card is unrecoverable. (It's a free program, but it's worth a lot more than these file unerase programs that sell for good prices.)
    05-24-2014 09:34 PM
  22. harrryyyy's Avatar
    try rubbing the card with rubber,
    08-26-2014 01:31 PM
  23. anonymous2015's Avatar
    I am having same problem , my memory card is inoperatable , i was charging it with my laptop and just suddenly disconnect the cable and open the camera and after that my phone got stuck , i have to take of the battery to restart my phone but when my phone switched on , my phone notify that "SD card unexpectedly removed" and then i took of memory card and connect it to my pc ,llaptop with card reader they not access it ,everytimes i click same answer "PLEASE INSERT DISK" wth ,i have very important stuff in my SD card i want it back please tell me if there is an option ??? waiting for your replies
    12-17-2014 05:23 AM
  24. anonymous2015's Avatar
    My memory card is inoperatable , i was charging it with my laptop and just suddenly disconnect the cable and open the camera and after that my phone got stuck , i have to take of the battery to restart my phone but when my phone switched on , my phone notify that "SD card unexpectedly removed" and then i took of memory card and connect it to my pc ,llaptop with card reader they not access it ,everytimes i click same answer "PLEASE INSERT DISK" wth ,i have very important stuff in my SD card i want it back please tell me if there is an option ??? waiting for your replies
    12-17-2014 05:24 AM
  25. Becky Mullikin's Avatar
    Turn phone off, remove SD card, turn phone back on WITHOUT SD card in it, then, with phone on, insert SD card. Works for me. Honestly, if this problem repeats, back up your stuff once you card data shows up. I heard you should splurge on hardware once you choose to replace it. Hope this helps.
    05-13-2015 11:13 AM
29 12
  1. Micro SD card not recognized
    By KoukiFC3S in forum AT&T ATRIX
    Last Post: 05-30-2016, 12:35 AM
  2. sd card not working
    By MrEastwood#AC in forum AT&T Inspire 4G
    Last Post: 03-31-2011, 12:45 PM
  3. Micro SD card not recognized
    By jostarr in forum Barnes & Noble Nook Color
    Last Post: 02-13-2011, 07:30 PM
  4. CM6 - SD Card not working....
    By Kaneman in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 09-02-2010, 03:30 PM
  5. Android 2.2 - Move to SD Card not working
    By cgjja in forum Google / HTC Nexus One
    Last Post: 05-23-2010, 01:14 PM
