Results 1 to 4 of 4
- 09-25-2012, 08:52 AM
Thread Author #1
Android AAC streaming sounds artifacts
Hi, I stream music from Pandora and an app for local radio (tune in) quite a bit. But I've noticed a very annoying clicking/popping sound while listening. I've tried adjusting the stream quality in Pandora and the buffer amount in tune-in to no avail.
Tune-in has an option to change the current stream for the station if available (in my case aac to wma) and wma does not have the clicking sounds. My best guess is that Pandora uses aac to stream music.
Has anyone had similar problems with aac streaming or in general?
On a bionic ics leak 232 aokp rom.
Sent from my XT875 using Android Central Forums - 09-25-2012, 03:29 PM #2
Re: Android AAC streaming sounds artifacts
Could be the volume of the phone is too high? I know when playing lower bit rate audio, it is more prone to clipping at high volumes. Without hearing your phone, I'm just kinda guessing with this. If you are listening to headphones or using the aux jack to feed to external speakers, the Bionic is prone to getting pocket lint in the jack. It can make a popping sound when moving the jack plug around, or prevent the connection all together.
- 09-27-2012, 03:27 AM
Thread Author #3
This is actually present in every output, internal speakers, headphones, aux.. and at every volume level. Equalizers don't seem to help at all either. Plus, my roommates Xperia play has the same issues in Pandora.
This is partially why I am starting to point to aac playback/streaming.
If anyone has any other streaming apps that use aac, I'd love to try it in order to pinpoint this problem further. I'd also even like to try any non-aac streams as well.
Sent from my XT875 using Android Central Forums - 09-27-2012, 09:11 AM #4
Interesting. Did you also have this problem when you were on the stock rom? I'm also on a Bionic, running the standard 232 leak and listen to Pandora and another aac audio podcast. I've never had the popping issue.
One other thing you may want to check is the audio effects settings. If it's set to something like extreme bass, it may be just too much for the phone to handle. I kinda doubt that's it because you would hear something more akin to distortion to the beat, but it's all I can think of.
Napster on Android Free streaming
By warstory in forum Android ApplicationsReplies: 1Last Post: 10-02-2010, 07:13 AM -
Sound drops out on Android 2.1
By bakerjs in forum HTC Hero Rooting, ROMs, and HacksReplies: 11Last Post: 04-22-2010, 01:55 PM -
Streaming Hi-Quality Video To Android With Tversity and nswPlayer
By tallnerd1985#AC in forum General Help and How ToReplies: 0Last Post: 04-04-2010, 02:41 PM -
Android Sounds (Notification Sound) Download
By colbym#ac in forum Motorola DroidReplies: 0Last Post: 03-27-2010, 07:10 PM -
Any ways to get streaming shows on Android (ie. HULU)?
By DrDownload in forum Android ApplicationsReplies: 3Last Post: 01-30-2010, 07:10 PM
Reply
