I have never had a smart phone before and ill be getting on to the next 1 to 3 days its a Virgin Mobile chaser. and im planning to root it. (the question) whenever i root the phone , how should i update the phone , the apps , widgets , and ect?
Rooting the device will not change anything other than root access. If you are simply rooting and don't install a custom ROM then you will be able to update the phone via the phone settings (provided an update is available). Be advised that you may lose root if you accept an update.
Apps, widgets, games, etc. are still updated through the play store as an unrooted phone would. This still applies for a phone with a custom ROM. Welcome to the community and feel free to poke around/ask questions if you have any .
