DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 2 of 2
    GeekCop's Avatar
    Posts
    Global Posts
    139 Global Posts
    Default GMail not being pushed to phone
    Greetings.....About a week ago, I ceased receiving my Gmail messages automatically. If I go into Gmail and do a manual refresh, the messages will show up. I have a DINC2running stock Gingerbread. The only change I made about the time this happened was the installation of GO Launcher, which I've subsequently removed. I've done a battery pull as well as a data cache clean up, all to no avail.
    Ideas?
  2. #2
    Default Re: GMail not being pushed to phone
    Go to Settings-->Account & Sync-->[your account]-->Make sure "Gmail" is checked in there.
    (This menu option is different in Jelly Bean and i forgot the exact option in GB.)
    If you have cleared the data/cache then the gmail settings should have been restored to default but lets check gmail settings just to make sure.
    open Gmail-->[Menu]-->Settings-->[Your account]-->Make sure there is a check in "Email notification".
    Thanked by:
  1. Gmail not syncing properly from phone to web
    By trishakiefer in forum Android Applications
    Last Post: 07-19-2012, 12:33 PM
  2. Replies: 20
    Last Post: 12-27-2011, 10:00 AM
  3. Any frustration not being able to use your fingernail for small buttons?
    By whitenack in forum General Help and How To
    Last Post: 06-04-2010, 01:40 PM
  4. apps that cause the incredible to not be able to sleep
    By mobiledevice in forum Verizon Droid Incredible
    Last Post: 06-02-2010, 06:46 PM
  5. Imap not being pushed
    By Renocat in forum HTC Droid Eris
    Last Post: 01-07-2010, 05:33 PM
