Results 1 to 4 of 4
    Default Notification and alarm sound has stopped working
    Hope someone can help me out with this!
    My notification and alarm sound has stopped working however when I go to play music off my phone it still works.
    I have gone into the Volume section under Sound and tried to mess with the volume levels. When I turn the alarm level up to the highest it can go, instead of playing my alarm sound it plays a very faint beeping noise. When I turn up my notification level it makes a similar beeping noise.
    Does anyone know what is going on? I need to get this sorted ASAP.
    Cheers
  2. #2
    ansa82's Avatar
    Posts
    Global Posts
    206 Global Posts
    Default Re: Notification and alarm sound has stopped working
    What phone? I'm having notification tone issues with an LG phone
    Sent from my VS950 4G using Android Central Forums
  3. #3
    jimnyo's Avatar
    Posts
    Global Posts
    21 Global Posts
    my notification sounds aren't working either. i don't know why...i tried downloading sound managers and that doesn't help. i'm on an original htc evo 4g.
    - - - Updated - - -
  4. #4
    Hi:
    Mine don't work either on the Samsung Galaxy S II Skyrocket SGH-I727.
    It's either the 4.0.4 update that AT&T just did or the Ringo Pro update.
    When I go to re-assign a tone, I see three choices for each tone but only the third choice will work. Checked internal & external storage and have only 1 copy of the tones anywhere on the phone.
    Tried a battery & SD card pull to see if it was a fluke but it's still happening.
    Nothing but issues with Android OS. Looking to go back to blackbery next year or try Apple.
  1. Notification sounds randomly stop working
    By dragon718 in forum Verizon Galaxy Nexus
    Last Post: 10-28-2012, 04:24 PM
  2. Help: Market and other Google apps stopped working
    By Andy_S in forum Barnes & Noble Nook Color
    Last Post: 06-29-2011, 12:17 AM
  3. Netflix has stopped working for me
    By littlebone in forum Barnes & Noble Nook Color
    Last Post: 06-10-2011, 06:31 PM
  4. Calendar has stopped working after firmware upgrade
    By stevethepug in forum General Help and How To
    Last Post: 02-23-2011, 06:09 PM
  5. Replies: 3
    Last Post: 08-22-2010, 06:41 PM
