07-08-2014 01:46 PM
74 123
tools
  1. codysanbor's Avatar
    Try using the mobile YouTube site (m.youtube.com) from your desk/laptop. What happens?
    10-06-2012 04:19 AM
  2. codysanbor's Avatar
    Didn't work on chrome either
    10-06-2012 04:21 AM
  3. ShawnPaulN's Avatar
    Don't know how the rtsp protocol was included. Try YouTube - Broadcast Yourself..
    10-06-2012 10:29 AM
  4. visrant's Avatar
    Youtube has stopped working on the Galaxy nexus from Oct 1st for some reason. i tried factory reset, clearing cache, changing router settings, nothing works. very annoying
    10-06-2012 11:24 AM
  5. codysanbor's Avatar
    Ill try when I get home..
    I'm very frustrated with it
    10-06-2012 11:28 AM
  6. codysanbor's Avatar
    This is what I was told to do.
    This issue could be caused by a general connection issue. Please try the
    following steps to resolve this issue:
    - Change your internet/3G connection by toggling it off and then on again.
    - Reboot your device.
    - Sign in and out of Google Talk repeatedly to restore connection to our
    servers.
    10-06-2012 01:03 PM
  7. mscfl's Avatar
    So to complicate things even more, I connected to my dad's wifi (same isp) and everything works fine. WTF?
    10-06-2012 03:35 PM
  8. bigcatman's Avatar
    I'm glad it isn't working for other people either. It's only been in the last few days that it has stopped working with my wifi. I've tried literally everything you can to reset. I also tried it at my work on wifi and it didn't work so I know it's not my router. Something must be going on with Google's side.
    10-06-2012 05:01 PM
  9. codysanbor's Avatar
    See that don't make since.. That's crazy
    10-06-2012 05:02 PM
  10. cyanogen-man's Avatar
    What ISP are you guys using? Some ISP servers don't play nice with Google ??
    INSPIRE AOKP ICE COLD SANDWICH ROM
    10-06-2012 05:08 PM
  11. bigcatman's Avatar
    I have Metrocast in NH. It's always worked fine. And it works fine on my PC. Just not on my 4 varying Android devices. It's not on my end.
    10-06-2012 05:19 PM
  12. rkcfan's Avatar
    I'm in NH as well. Also on metrocast. Having the same issues. Everything but YouTube seems to work on wifi.
    Sent from my SPH-D710 using Android Central Forums
    10-06-2012 05:23 PM
  13. codysanbor's Avatar
    It's getting on not working that's for sure
    10-06-2012 05:56 PM
  14. ShawnPaulN's Avatar
    I'd still like to see the response from YouTube - Broadcast Yourself..
    10-06-2012 07:56 PM
  15. codysanbor's Avatar
    Won't play video under mobile.
    Reg site it will
    10-06-2012 09:03 PM
  16. Cellmeister's Avatar
    This is a Router / AP issue especially if your device works on another WiFi Router/AP
    FYI: That cell phones, iPhones, tablets use a generic "N" chip for WiFi (cheap version chip) & only run on the 2.4 MHz band
    ● Try rebooting your Router/AP (shut it off via power supply for a few minutes & then plug it back in.
    ● If you changed or altered your Router/AP settings put them back to where they where or back to stock & start again
    ● Verify which WiFi Encryption method is compatible with your device
    ● Make sure your not running your Router / AP on dual band or 40 mHz because you will get a
    Wifi signal, it won't work and it is usually not compatible for use with these devices.
    ● So I would check your Router/ AP settings especially if your WiFi, use basic settings with password & compatible encryption
    This issue would not have anything to do with your ISP, it is a Router / AP setting issue
    Hope that helps
    10-07-2012 01:16 PM
  17. codysanbor's Avatar
    Hope that helps
    So what settings should I use?
    10-07-2012 01:33 PM
  18. codysanbor's Avatar
    I reset my router and made it open no password default settings and still doesn't work.
    So i believe it's a Google thing
    10-07-2012 02:43 PM
  19. mscfl's Avatar
    Hope that helps
    I appreciate the help, but I don't see how this can be the issue. I could see it being a conflict between Youtube and certain routers and ISPs. Mine was working up until the 1st and NO changes have been made to any of my router or modem settings. It would have to be something that changed on Youtube's end right? Unless all of our various ISPs changed some setting,,,,
    10-07-2012 04:03 PM
  20. rkcfan's Avatar
    I haven't changed anything on my end either. YouTube will play in the browser but not in the mobile site.
    10-07-2012 04:06 PM
  21. codysanbor's Avatar
    My nexus doesn't have flash so I can't check that
    10-07-2012 04:24 PM
  22. bigcatman's Avatar
    Hope that helps
    I appreciate you trying to help, but that's just not true. YouTube worked fine for me up until a few days ago. It doesn't work on my default settings router that I reset 3 times, nor does it work on my work wifi which is a different brand of router. I've tried everything I can think of (I'm a computer repair tech) and I have come up empty. It has to be YouTube's fault.
    10-07-2012 04:38 PM
  23. Aegeis's Avatar
    I am the IT director for a school district here in CT. Youtube works fine on our laptops and desktops connected to our fiber-Internet connection. We have a wifi router connected to a cable modem from Metrocast of CT for vendors to access the Internet... laptops used to access Youtube on it work fine, mobile devices like iPhones, iPod Touch and the Nexus 7 fail continuously. Metrocast blames in on Google changing something.
    Just curious how many other people are having this same problem, have Metrocast, and are using a wireless B/G (not N) router...
    Quickest fix: Change the DNS server setting on your device to 8.8.8.8 which is Google's DNS server.
    bigcatman and booyamachine like this.
    10-07-2012 08:37 PM
  24. cja1782's Avatar
    I have metrocast in Va king George county and I'm having the issue still. I went to another wifi and it works. The people from metrocast came out and the tech said he's having the same issue at his home with his daughters ipod with YouTube while on wifi. I they are monitoring my line to see what they can discover.
    10-07-2012 09:46 PM
  25. bigcatman's Avatar
    So it's metrocast? Grr. I'm going to give them a call tomorrow.
    10-07-2012 10:04 PM
74 123
  1. Need some help, ROM Manager not working right
    By grazamataz in forum T-Mobile Vibrant Rooting, ROMs, and Hacks
    Last Post: 09-15-2011, 07:42 AM
  2. Need some help, ROM Manager not working right
  3. Youtube not working on 3g (only on wifi)
    By Peter_bchs in forum HTC EVO 4G
    Last Post: 04-01-2011, 11:49 PM
  4. Bluetooth and youtube not working on ANY custom rom
    By samirv79 in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 03-24-2011, 05:21 AM
  5. D2 wifi disaster - need help asap!!!
    By Rev2010 in forum Motorola Droid 2
    Last Post: 12-09-2010, 09:25 AM
