Cellmeister
Re: Need help... asap... Youtube not working on WIfi on Nexus 7 and Iphone 4
This is a Router / AP issue especially if your device works on another WiFi Router/AP
FYI: That cell phones, iPhones, tablets use a generic "N" chip for WiFi (cheap version chip) & only run on the 2.4 MHz band
● Try rebooting your Router/AP (shut it off via power supply for a few minutes & then plug it back in.
● If you changed or altered your Router/AP settings put them back to where they where or back to stock & start again
● Verify which WiFi Encryption method is compatible with your device
● Make sure your not running your Router / AP on dual band or 40 mHz because you will get a
Wifi signal, it won't work and it is usually not compatible for use with these devices.
● So I would check your Router/ AP settings especially if your WiFi, use basic settings with password & compatible encryption
This issue would not have anything to do with your ISP, it is a Router / AP setting issue
Hope that helps
Hope that helps
