For future knowledge, it sounds as if either the "bar" in the port got bent or there's dirt in the port. If you look into the port in a strong light with a good magnifier, you can usually see the problem and fix it with a needle. Once you;ve done one, it takes about 60 seconds to fix one.
(You may also get an indication that the phone is charging when it's not plugged in with this problem.)
Sent from my Precedent using Android Central Forums
