Results 1 to 15 of 15
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Cheapest/Best solution to fix a cracked screen(functional otherwise)
    Hello All. I went through a few threads here And then other places on the web and they didn't help really all, so here it goes I guess:
    I have VZW Samsung Fascinate that has been sitting in my drawer. It has a pretty badly cracked screen, that's the big problem. What's funny about it is the on screen capacitive buttons still light and appear to be responding to touch by sounds I'm hearing when I press the buttons. It also seems to be vibrating to certain touches as its suppose to. So it appears to be functioning the way it suppose to other than the cracked screen which keeps.me from seeing anything. The biggest damage to the screen is near/underneath the ear piece.I have a few pics but I don't know of a way to post them from being on the mobile website. I will definitely post them later if needed. It also seems to be charging as well.
    OK so i have this phone that I'm instersted in getting the screen repaired. I've never had this issue with a phone before but i would be willing to do it myself. But what I would Like to know is how to find out what exactly I need and where to get it for the best price.
    From what I understand, there is the screen, the digitizer, and the LCD. I was trying to be specific as possible so I will know exactly what I need and don't need to buy. I'm trying to spend as less as possible, some of the things I've looked at were around 80, and tbh I don't want to put that much into this project. What makes this so expensive? Especially given the phone is quite old now.
    Like I said I don't know enough about this exact thing but hopefully someone out there will know more than me and lead me in the right way. If I didn't give enough info, please let me know this
    Also I hope I posted this in the right section. If not I'm sorry and please move it.
    I do have pics I can post asap if needed.
    Thank you all for your time. If you need anything from me I'll be checking all through today.
  2. #2
    Cellmeister's Avatar
    Posts
    Global Posts
    327 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Cheapest/Best solution to fix a cracked screen(functional otherwise)
    My quick opinion:
    Even if your technically capable of dismantling your phone, the parts may not even be available anymore,
    you could probably pick up another or even better phone for less than $80- on Craigslist then just
    transfer your ESN to it. Just be sure the ESN is clean, meet any seller at a Verizon store just so
    they can verify the bill is paid & the ESN is clean.
    my 0.02
    Hope it may help
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello Cell.
    Thanks for the reply. I think your prob right if it was main phone. Since I just had it sitting around, I figured I would try to get it working as maybe a 2nd screw around phone, or something like that.
    And yeah there is a bunch of LCD/digitizer packs on eBay and a few other places, I just don't know for sure what I need to replace. See the screen is all spiderwebbed and cracked yet the capacitive buttons still light up and respond to touch So what I can't be sure of is if the still functioning touch screen makes a difference in what I need to buy.
  4. #4
    Locool676's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Harmonia 2
    Have you checked eBay for the parts. Most of the time (although I have not looked for your phone) you can find the whole assembly for under 40 with the opening kit. That's where I go when I need any parts, eBay.
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Locoo
    Yeah I been looking, if I could find for under 40 I d be cool with that, but I'm not seeing that just yet.
    Hey do you happen to know whether it would matter if my touch screen still functioned? The screen is all cracked/spider webbed and I can't see anything but the buttons still work like they should. They still light up. Still respond to. Touch. Would this matter or would I have still have to buy the whole pack rather than just glass screen( if poss)
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey here are 2 pics of the damage screen. Hope this helps In giving me advice.
    Thanks
    Sent from my Galaxy Nexus
    Attached Thumbnails Attached Thumbnails Cheapest/Best solution to fix a cracked screen(functional otherwise)-uploadfromtaptalk1349642850643.jpg   Cheapest/Best solution to fix a cracked screen(functional otherwise)-uploadfromtaptalk1349642861881.jpg
  7. #7
    Locool676's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Harmonia 2
    From my point of view, you would have to replace the glass and LCD screen.
    However, it's really expensive to do so for this phone. My opinion is to sell it for a little bit, then add that to what you would of spent on the LCD and get a new toy.
    I could not find anything under $80 to fix this.
  8. Thread Author  Thread Author    #8
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: Cheapest/Best solution to fix a cracked screen(functional otherwise)
    Hey Locool.
    well thanks man for even taking the time. I apprec that.
    If im looking for the correct thing, which is typing in Samsung Fascinate LCD replacement. I see the word "digitizer' included. Im not sure if this is a common part of the replacement kit I will have to purchase or do i not need this digitizer. Like i said, if im looking at the right thing< the cheapest im findind is 65-75 including shipping.
    What is funny is I found a few of this exact phone for 50 bucs. LOL I guess i could buy that. It is just a weird situation. I have a phone sitting here that would be cool just to flash roms and try other with a defective screen only being the problem. But trying tofix it would cost more than the price of an actual used one of these. Dam this sucks
    If only there was the perfect (Fix) or (Solve) for this particular threAD://///////> I know I said it before but this sucks..
    Locoo....again thank you for trying to help
  9. #9
    Zero Hunter's Avatar
    Posts
    Global Posts
    86 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    holy cow....that screen is FUBAR lol
    But on a positive note. Yes, you can buy the whole screen assembly from eBay. Just note that it's not OEM...and all the ones there are made by chinese manufacturers. However from what I have seen they DO work and on an older phones, it's just a smarter thing to do.
    If you get stumped. Just go to youtube and there are tons of videos that can walk you thru the process.
    htcevo4g03 likes this.
  10. #10
    repairsuniverse's Avatar
    Posts
    Global Posts
    8 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are many generic imitation parts out there with very cheap components but we offer the best high quality parts that are specifically designed for your device. We also offer FREE technical support for our customers if they require it. We suggest replacing the touch screen digitizer+LCD combo and we have everything you will need for the repair. You don't have to buy a new phone or pay someone to fix it. Feel free to ask any question on our Live Chat feature at Repairs Universe │ iPhone, iPod, HTC, Motorola Parts & Repair Guides
  11. #11
    Locool676's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Harmonia 2
    Quote Originally Posted by repairsuniverse View Post
    Whoa, $110 for the assembly is the highest I've seen so far. How old is this phone that parts have to be out of print and expensive?
    4g03, you can just buy another phone and doctor yours, but it's just a bit too silly in my opinion to do so.
    For reference, the assembly for my phone is about $30, screen and digitizer.
  12. Thread Author  Thread Author    #12
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Zero Hunter View Post
    Thanks for
    Reply. Haha screen sure is. What's crazy is I found this phone in a parking lot, with the actual peel sticker still on the phone from when its brand new. It almost looks like someone purposely removed part of the screen right under the ear piece but I could be wrong. But yeah that's why its so damaged. It was sitting hear for a while and one day I thought about trying to bring it back to life. After I did some looking, its seems some if the LCD screens for sale are almost double the price of the actual used phone I could buy . So I'm clueless on what to do. I so know one thing though, that im not paying 110 for a new LCD.
  13. Thread Author  Thread Author    #13
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I gotcha. I was just making the point that for half the price I would pay you for the kit, I could get the phone with out a cracked screen. You understand what I'm saying? I realize I don't HAVE to buy a another fascinate but when I can get one with an already fixed screen for half of the price I would pay for a kit, see what im saying?
  14. Thread Author  Thread Author    #14
    htcevo4g03's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Locool676 View Post
    Hey. Yeah the phone is at least a few years old. I get what your saying. I could just get another phone for HALF the price of the this LCD kit. Wow your saying the thing for your phone is 30? Dam man why is the Samsung Fascinates so much?
    Figures..
    If it was 50 I would scoop it, but how can pay ever pay any more for it when I can get the same phone with a screen that's perfectly fine for around the same price right?
    I realize the dude is just trying to make sale for his business but it gotta be tough for even him to admit that buying his product would be best In my situation.
  15. #15
    Desseray Altamira's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    what is the cheapest way to fix my lcd screen ?
  1. Tighten screws to fix some loose screens
    By 1812dave in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-18-2012, 08:53 PM
  2. My plan on fixing my cracked screen will it work?
    By boriecorie in forum HTC Evo Shift 4G Rooting, ROMs, and Hacks
    Last Post: 05-13-2011, 02:39 PM
  3. Cheapest/best place to buy a Thunderbolt?
    By newdad28 in forum Verizon HTC Thunderbolt
    Last Post: 04-29-2011, 08:17 AM
  4. Best way to fix market?
    By E_man in forum Barnes & Noble Nook Color
    Last Post: 02-21-2011, 03:53 PM
  5. So what is the best way to protect my EVO screen?
    By krisrock in forum EVO Accessories
    Last Post: 08-06-2010, 08:27 PM
