I figured out how to rename backups
Llawen
14
I figured out how to rename backups and they load. I have tried this and can confirm it does work on safe strap 2.11.
Instructions
Using root explorer type app
Go to SD card ext
Then safe strap
then backups
Choose a backup to rename. It will be in this format.
Safe-2012.10.6.02.05.30
The first set of numbers is the date 2012.10.6
.02.05.30 is the md5
This must not change or you will get md5 miss match error.
Also leave safe
change it to look like this
Safe-axiomcs.02.05.30
Thus delete date only and add whatever you want to rename it to.
To get to rename option just long press backup and there it is.
Enjoy.
Sent from my XT875 using Tapatalk 2
