Results 1 to 4 of 4
- 10-08-2012, 08:27 AM
Thread Author #1
Will performing a factory reset lock my phone
Hello all,
I am a bit of a newbie with these things so here is my situation :
I am having major battery draining issues with my phone, i have read about all the tips and tricks and trying to get to the bottom of it, but nothing seems to be helping. I read that doing a factory reset might help the situation. I just want to make sure that if i do that, that my phone will still remain unlocked to any carrier I want.
Thank you! - 10-08-2012, 07:53 PM #2
Re: Will performing a factory reset lock my phone
SIM locking and factory reset have nothing to do with each other.
But factory reset and battery use have nothing to do with each other either.
Use Startup Manager (free) to make sure that the phone doesn't start with a lot of crap you don't need running.
And be realistic about what you expect from the battery. A week with 3G, Wifi and GPS running is more than you'll get. - 10-08-2012, 08:06 PM
Thread Author #3
Thank you very much for the advice! I actually found a great solution which is juice defender, and I don't have to charge my phone three times a day anymore. I pretty much know that excessive use of the phone can't make miracles but when I noticed that my phone was draining the battery by 40%over night with no usage, I thought I would try anything.
Thanks for the info on the original question as well regarding factory unlock and reset. This is a great and helpful forum! - 10-08-2012, 10:24 PM #4
Have email set to sync once an hour or less, and have everything that you don't need turned off at night. (If you're okay syncing your email in the morning, turn off syncing, 3G and wifi at night.) Every app that's running draws current and every radio that's turned on draws current.
Will flashing the Takju factory image wipe my phone's data?
By emmib in forum Google / Samsung Galaxy NexusReplies: 1Last Post: 07-16-2012, 05:55 PM -
Factory Reset bricked my phone
By arashed31 in forum Virgin Mobile Optimus VReplies: 23Last Post: 05-25-2012, 08:50 PM -
Factory Reset Locked Phone!?!?!
By kissymissy505 in forum Sprint Nexus S 4GReplies: 4Last Post: 11-08-2011, 06:04 PM -
Considering factory reset of my Incredible, will I lose my OTA Froyo update?
By acman319 in forum Verizon Droid IncredibleReplies: 4Last Post: 05-11-2011, 08:57 AM -
Factory Reset wiped my Apps from AppBrain
By androidvirgin in forum HTC EVO 4GReplies: 8Last Post: 08-14-2010, 10:04 AM
Reply
