1. Accidental's Avatar
    I am looking for an app/widget to add a tiny bit of convenience to my life. I want the ability to tap on an icon on my homescreen that will trigger a (Bluetooth) connect to a device that I have paired with in the past. A one-tap-and-you're-done widget would be perfect. I have a Bluetooth dongle in my car that I connect to quite often that plays music over a stereo system (HTC Stereoclip A100). The device is paired with my phone, but I must go to Bluetooth Settings and click on the device to connect every time I get into my car.
    I have tried a few apps in the Marketplace with no luck. I am using ICS (HTC EVO 4G LTE). One specific app that worked, but no longer works in ICS:
    Bluetooth Profile Widget
    https://play.google.com/store/apps/d...bHVldG9vdGgiXQ..
    If there is a thread that already answers this question, please point me to it. I was unable to find one that addressed this question.
    10-08-2012 05:00 PM
  2. Rukbat's Avatar
    Have you tried not turning the device on until you have Bluetooth enabled in the phone? Most devices will connect when you turn them on, if a devide they're paired to is within range.
    Accidental likes this.
    10-08-2012 10:20 PM
  3. Accidental's Avatar
    You know Rukbat, I'm not sure why I didn't try that. Worked just fine! I'll use my Bluetooth Radio On/Off widget now.
    10-09-2012 08:38 AM
  1. Can I connect to two bluetooth devices?
    By shinsen1378 in forum Samsung Galaxy S II Skyrocket
    Last Post: 09-12-2012, 10:29 AM
  2. trouble with connect to pc -- USB device not recognized
    By chickenapplesausage in forum T-Mobile HTC Sensation
    Last Post: 09-30-2011, 04:37 PM
  3. Optimus one not connecting to laptop wifi hotspot
    By harrymama in forum General Help and How To
    Last Post: 08-22-2011, 10:39 AM
  4. Nexus One connecting to OS X????
    By LCW in forum Google / HTC Nexus One
    Last Post: 06-29-2010, 02:09 PM
  5. evo connect to multiple bluetooth devices
    By mbmatt11 in forum EVO Accessories
    Last Post: 06-21-2010, 05:33 PM
