1. df79transam's Avatar
    I'm having a fit to get one of these but i dont want to pay $30 for stickers. I'm hoping someone can put up their opinions on this product and how you like it, pros and cons.
    10-10-2012 09:15 PM
  2. dizzle16's Avatar
    I've bought several of them and imo they're good for the rest of the phone but the screen. Problem is application is a b!+ch. Again this is just my experience but for the screen they will protect the surface just great. Definitely better than the cheap protectors. But application is a pain. Anything like hair or lint that's in the air will create bubbles if trapped underneath so be careful because it will make your screen look hideous when the screen is off. Now I have applied some (I've really bought like 4 or 5 of them) with only one or two bubbles and it looks great but my next problem was after about 3 months or so (depending on how often you use device) I had a buildup of small scratches on my screen and it wasn't sexy at all. I Decided to remove the protector each time because I couldn't stand the sight of it. Again the screen was totally protected but the protector will eventually show signs of wear. Now the body applicator looks great but collects lint from your pocket if your application is off in the slightest. Nowadays I don't use a screen protector or case at all. I have a Sprint evo 3d and I decided to not use a screen protector and just be careful. I hold my hand tightly when I walk. I don't put it in the same pants pocket as anything (keys, lighter, smokes) and I always have the screen facing my thigh when it's In my pocket in case someone bumps into me or vice versa. I have insurance as well. And I think this phone has gorilla glass so I'm not worried. My advice. Buy a phantom and see if it's for you. Maybe you can apply it with ease or avoid the small scratches and pocket debris buildup. Everybody is different.
    Sent from my PG86100 using Tapatalk 2
    10-10-2012 09:37 PM
  3. df79transam's Avatar
    I am digging their full body skins, im wanting one of their woodgrain pattern designs, and plus you get two screen protectors when you purchase their full body skins. I have a razr maxx, and i love how thin it is and don't want to add alot of bulk, and im very careful with my electronics, i dont drop stuff all the time but I am concerned with the everyday scratches, sitting it on a table and it rubbing kind of stuff.
    10-10-2012 09:45 PM
  4. Slender Troll's Avatar
    If you are looking for a good screen cover i use an anti glare screen protector that was made for the HTC Evo 3D but it works great for my Motorola Photon 4G. Dont know what phone you have so it might not fit your screen. Hope this helps
    Sent from my MB855 using Android Central Forums
    Attached Thumbnails Phantom Skinz, worth it or waste of money-uploadfromtaptalk1349923909108.jpg
    10-10-2012 09:52 PM
  5. df79transam's Avatar
    I'm looking for all around protection, screen, sides, back, edges, the whole thing, I don't want to put this phone in a case, I like the naked feel but I'd like to have a bit of protection to, have my cake and eat it to kind of sense. If I can get some opinions from the community here, it would help in my decision making process.
    10-10-2012 09:57 PM
  6. sropedia's Avatar
    I have the casemate barely there case and I can hardly tell it's on my one x. It also gives it a little bit of extra grip and looks fantastic
    Sent from my HTC One X using Android Central Forums
    10-11-2012 09:04 AM
  7. df79transam's Avatar
    I have had my sights set on the case mate barely there case for the razr maxx, and i like it to, it cost just as much as the stickers from Phantom Skinz does and your actually getting more for your money.
    10-11-2012 12:30 PM
  8. Zero Hunter's Avatar
    I had one of these on my previous phones and made the mistake of trying to install it myself and botched it.
    It's harder than it looks. If you are already spending that much on a protector, just pay a little extra and have a shop do it for you prefessionally. Especially if you are really anal about getting everything perfect.
    10-11-2012 07:36 PM
  9. df79transam's Avatar
    Oh I'm definitely anal about my electronics
    10-11-2012 09:47 PM
  1. Worth it or not?
    By Jrid32 in forum Samsung Galaxy Tab 10-inch
    Last Post: 04-11-2012, 02:41 PM
  2. prevail issues anybody else having it or know of a fix.
    By boostedgst97 in forum Boost Mobile Prevail
    Last Post: 02-06-2012, 12:41 PM
  3. 4G experiences? Worth it or wait?
    By kharrigan in forum Phone Wars
    Last Post: 01-12-2012, 03:49 AM
  4. What is the point of root and is it worth it or not
    By N9tShadow in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 12-22-2011, 04:58 PM
  5. advanced task killers worth it or the culprit?
    By houseofgrafx in forum Motorola Droid 3
    Last Post: 09-15-2011, 10:18 AM
