1. shemshadey's Avatar
    I have a samsung galaxy s3 and i cant transfer anything to my macbook ive tried changing the usb setting to MTP but the android file transfer still says please connect with a usb cable????? can someone please help??
    10-13-2012 02:59 PM
  2. B. Diddy's Avatar
    I don't have a Mac, but according to the Verizon Galaxy S3 manual (link here: http://downloadcenter.samsung.com/co...ual_LG1_F5.pdf), you need to install this program on your Mac: Android.com
    10-13-2012 05:33 PM
  3. shemshadey's Avatar
    yeah i did download that app and it wont work!!! when i open it when my phone is connected it just tells me '' no android device found please connect your android device with a usb cable to get started'' like wtf
    10-17-2012 11:24 AM
  4. Zero Hunter's Avatar
    I had a similar problem before....after hours of trial and error, resetting drivers, and tech support....It turned out I had a bad cable. Go figure.
    10-17-2012 07:03 PM
  5. B. Diddy's Avatar
    Are you using the original USB cable or a 3rd party one?
    10-17-2012 10:20 PM
  6. Jarnld's Avatar
    95% of the time......................bad cable. In your case I'd say 100%....especially since its not doing anything..
    10-22-2012 12:20 PM
  7. shemshadey's Avatar
    the original!
    - - - Updated - - -
    Ok I'll go buy a new one and see thanks.
    10-27-2012 06:33 AM
  8. ThePurpleAndroid's Avatar
    If you have a home wifi connection, get a wifi transfer app. I use Wifi File Explorer.
    ~~HTC Evo Design~~
    11-05-2012 03:05 AM
  1. Replies: 1
    Last Post: 03-16-2012, 12:08 PM
  2. Help needed: transferring apps to my new Epic Touch
    By locationman52 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 09-16-2011, 09:35 PM
  3. Replies: 0
    Last Post: 06-30-2011, 12:46 AM
  4. cant transfer photos to SD card
    By donover58 in forum Motorola Droid 2
    Last Post: 02-14-2011, 09:04 AM
  5. Having trouble syncing to my computer. HELP please
    By cdolan22 in forum Verizon Droid Incredible
    Last Post: 06-21-2010, 01:39 PM
