1. terrashand's Avatar
    I have an Android 2.3 phone with no service contract. My wife has a laptop with a non-working wifi card.
    Question: With an app like PDANet and that phone can I hook the phone to my home wifi and tether it to the wife's laptop and her have internet again?
    10-14-2012 02:19 AM
  2. still1's Avatar
    yes,
    10-14-2012 10:40 AM
  3. Rukbat's Avatar
    You can get a wifi card for most laptops on eBay for about $30-$40. It's located under one of the removable panels on the bottom of the laptop. Just remove the wires from the old card one by one and plug them into the new card. Be careful with the stiff wire - that's the antenna cable. Don't bend or kink it.
    (Make sure that the wifi switch on the laptop [the airplane mode switch] isn't turned off. I've seen a lot of "bad wifi cards" caused by inadvertently brushing past that switch.)
    10-14-2012 06:11 PM
  4. terrashand's Avatar
    Aye but I have 3 kids I don't have 40 bucks haha. The question was really if tethering would work without a contract. I can mess with laptops and phones but personally if I am holding a phone it should makes calls rather a company has it in their computers or not. That's just me though. Thanks for the help folks.
    10-14-2012 09:39 PM
  1. Wifi tethering question
    By GreggoryD502 in forum T-Mobile Vibrant
    Last Post: 09-11-2010, 01:40 PM
  2. Tethering Question (i know again)
    By wakebrdr94 in forum Motorola Droid X
    Last Post: 09-07-2010, 09:20 AM
  3. Tethering Question
    By katrina2475 in forum Motorola Droid X
    Last Post: 09-02-2010, 04:03 PM
  4. Tethering and The Barncle Wifi Tethering question
    By thataznguy#AC in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 08-03-2010, 07:01 PM
  5. Tethering Question About My EVO
    By Setite in forum HTC EVO 4G
    Last Post: 05-28-2010, 06:26 PM
