Results 1 to 4 of 4
    Default Default video player Droid Bionic
    Hello, I inadvertantly made the built-in video player the default and I can't figure out how to undo that. Here's how I got here.
    I use Beyond Pod for video podcasts. I also have MX Video Player which I like. Everytime I update MX, then next time I click on a video to watch in BeyondPod it asks me what I want to use for the default video player. In BeyondPod I already have it set for external player which means do not use BeyondPods' player but use something external to it...such as the Bionic built-in player OR MX Video player. So when BeyondPod asked this time, I accidentally clicked on built-in video player after clicking don't ask me again instead of choosing MX Video Player. And now I can't figure out how to undo that. The settings in MX don't seem to change anything...all I can do is pick between internal (BeyondPod's player) or external...which now only gets me the built-in player. I looked in the general settings in Android and can't find a setting for that. The built-in player is not in the app drawer so I can't find any settings for that. So I'm stuck. The built-in player only plays in landscape in one direction...the direction with the charging micro-USB plug down...so there's no way to play video while charging because the phone won't sit flat on that side with the plug sticking out of what the built-in player thinks is the bottom side. In Windows when you have a file type associated with a particular program you can change that anytime. Can you not make changes in Android? Can anyone help with this? Thanks.
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: Default video player Droid Bionic
    Manage Apps >> Whatever Default Player Is Called >> Clear Defaults.
    Thanked by:
    Bingo. That did it. Thanks for teaching me something.
    Sent from my DROID BIONIC using Tapatalk 2
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    No problem. Glad I could help.
    Sent from my DROID X2 using Android Central Forums
  1. How To Change The Default Video Player?
    By the2ndflood in forum General Help and How To
    Last Post: 12-23-2011, 05:22 PM
  2. Droid Bionic Video 9/6/11
    By javikid in forum Droid Bionic
    Last Post: 09-06-2011, 10:01 PM
  3. Droid Bionic Hands-On video and benchmarks
    By patfactorx in forum General News & Discussion
    Last Post: 09-05-2011, 02:44 AM
  4. Default Video Player on Nexus S?
    By carpetmaven2000 in forum Sprint Nexus S 4G
    Last Post: 05-08-2011, 06:35 PM
