Results 1 to 4 of 4
- 10-23-2012, 05:31 AM
Thread Author #1
Webcam Question
So here is the deal. I have read thru a bunch of forums and having trouble finding an answer. The question I have is, I have an Evo 4g laying around NOT ACTIVAVTED, how do I use the phone as a webcam on my wifi network at home and remote view it on 3g/4g on my gnex? Everything I have found allows you to use the phone as a webcam but only let's you view the cam if on the same wifi network. I need something for when I'm at work so I can log on and just check in. Also, my computer is not working correctly so hooking anything up to the PC is out of the question. Thanks for any and all responses
Sent from my Galaxy Nexus using Tapatalk 2 - 10-23-2012, 12:53 PM #2
Re: Webcam Question
You could try putting the phone at home into a hangout, then you can could join on G+ at work.
- 10-23-2012, 05:13 PM
Thread Author #3
- 10-24-2012, 08:25 AM #4
Re: Webcam Question
Does it close the hangout because you were the only two people in the hangout? If so, do you have any other device you could have join the hangout as well, so it isn't automatically closed?
G1 Questions
By joeperrin2121 in forum T-Mobile G1Replies: 10Last Post: 05-15-2013, 09:34 AM -
Copy / paste question
By FAndroid in forum General Help and How ToReplies: 5Last Post: 03-18-2013, 12:02 AM -
HTC Hero Questions
By Chaos_Fonez in forum HTC HeroReplies: 24Last Post: 10-06-2009, 10:08 AM -
Misc android/g1 questions
By ericdroid in forum General Help and How ToReplies: 1Last Post: 01-15-2009, 10:46 AM -
Contacts Question
By EastBay in forum General Help and How ToReplies: 0Last Post: 12-31-2008, 01:42 PM
Reply
