Re: Help me find a phone?
The S2 is a good phone with lots of space and a big screen. Check Amazon and Ebay. Double check the device and make sure it's programmed for Sprint before you buy it. I wouldn't use Craigslist for a phone purchase. You can also check local used cellphone shops or pawn shops.
~°~HTC Evo Design~°~
Check swappa as well. You can find decent deals there
Sent from my SCH-I535 using Tapatalk 2
Go to [Only registered and activated users can see links. Click Here To Register...] and ask for your requirements. It might help you to find your desired phone.
