What I found that worked for me after searching and searching the net for a quick solution since I rooted my Bionic and all the other Treads I've read didn't work for me either. So this is just for some of the masses not all, you must have to have Titanium Backup already installed. If so go in and unfreeze all of the bloatware (app-only) that Verizon has place on your device. It may take a min to do but once completed go to settings>about phone>system updates. Download the update and install your phone should reboot after the download completes at 100% then you will get the icon of a box with driod bot standing outstide once this shows it will take awhile to get it all installed so just put it on the charger and leave it. But once it is installed you will have to re root your phone since it will be overwritten. Hope this helps.....
