Results 1 to 8 of 8
    Default Samsung Transform Ultra charging port problem
    Problem is that the phone wouldn't charge this morning. After a little wiggling on the cord it finally started charging. Once I unplugged it the phone started to act like someone was continually plugging and unplugging the charger cord. This evening I pushed a screwdriver across some of the contacts and around the port, now it's acting normal, but when I plug the cord in it doesn't have the same snap or pop into place that it once had. Any help would be appreciated, Thank you.
    Sent from my SPH-M930BST using Android Central Forums
  2. #2
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    Default Re: Samsung Transform Ultra charging port problem
    Look at the port with a good magnifier and in a good light. Compare what you see to a good port (in another phone, maybe). The problem is usually some dirt in the port or something bent.
    Thanked by:
    I have called Samsung and it would be nice if they just sent me a refurbished phone since it's still under warranty. It would make a nice Christmas gift for my sister, since I've already bought a new Samsung Galaxy SII through Boost Mobile.
    Sent from my SPH-D710BST using Android Central Forums
  4. #4
    Could also be the cord. I know I had issues when in had the Transform Ultra, but I got a new charger and it worked fine.
    °~¤~°HTC Evo Design°~¤~°
    ~*Purple Android*~
    Thanked by:
  5. #5
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Contact the carrier to get it replaced. That's how it works with Verizon anyway.
    Thanked by:
    So my old Samsung Transform Ultra came back with a new battery and I am assuming a repaired charging port. I don't really know what they did to the port because the invoice just said replaced component, it does work now and I gave it as a gift to my sister.
    Sent from my Boost Galaxy SII.
  7. #7
    Thanks, Rukbat!
    my STU just started doing that, yesterday.
    Unfortunately, no one around me has the microUSB port on their phones.
    What is it supposed to look like when I see it?
    Any help would be greatly appreciated!
    Thanks again!
  8. #8
    Seems to the plug port has the bad contact.
    If you want to know something about flash player go to this blog flash-video-player.blogspot.com
  1. Samsung Transform Ultra 1st Rom by Interdpth
    By Growjunky in forum Samsung Transform
    Last Post: 09-05-2012, 02:14 AM
  2. Samsung Transform Ultra or ZTE Warp for Boost?
    By RebeccaMI in forum Other US Carriers
    Last Post: 06-09-2012, 05:17 AM
  3. Whats better the LG Marquee or Samsung Transform Ultra?
    By DeadStarState in forum General Help and How To
    Last Post: 02-03-2012, 12:56 PM
  4. Boost Mobile Samsung Transform Ultra
    By sportsinger75 in forum Rumored Devices
    Last Post: 10-27-2011, 06:14 PM
  5. Charging port problems...
    By EvoRoy in forum HTC EVO 4G
    Last Post: 10-01-2010, 04:59 AM
