Results 1 to 2 of 2
    Default How do I... ?
    I replace my Motorola Triumph with Kyocera Rise. To my surprise, it's actually so much better with all the problems Triumph has.
    This is just a minor problem and I don't know if there's a solution to it. I use a old GPS Tracker by Instamapper on my phone. I have a feeling it's no longer supported since the website and the app haven't been updated for a while.
    What I have noticed, the new phone actually disable the GPS Tracker after couple of hours of running in the background.
    I try to disable the Eco Mode but that seems not to work.
    So is there a solution to this problem? Thanks!
    If not, is there another program I could use and that is free that is a good replacement for GPS Tracker?
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: How do I... ?
    I just searched Play for GPS Tracker and there are two apps that came up that were listed first and free. Why don't you give them a try and post back what you think about them.
  1. How do you clean the Hero's track ball?
    By Slvrshot in forum HTC Hero
    Last Post: 07-13-2011, 07:53 PM
  2. How do you search email in Android 2.0?
    By rcliff#ac in forum General Help and How To
    Last Post: 10-28-2009, 06:34 PM
  3. How do i send a picture mail?
    By ICON76 in forum HTC Hero
    Last Post: 10-25-2009, 05:04 PM
  4. how do I backup my hero?
    By zeravla531 in forum HTC Hero
    Last Post: 10-16-2009, 09:45 AM
  5. How do you uninstall pre loaded applications?
    By sgtoaf in forum HTC Hero
    Last Post: 10-12-2009, 03:02 AM
