Results 1 to 3 of 3
    Default Network signal loss
    Last night my phone decided it wanted to be annoying and started turning itself on and off on its own. This has caused me to lose my network signal. Does anyone know of a way to fix this issue?
    So far, I have turned the phone off (had it powered down all night while I slept).
    Removed the sim card.
    Used the recovery options to clear the cache.
    Simulated a battery pull.
    Thus far, nothing has worked. Any suggestions will be greatly appreciated.
  2. #2
    Default Re: Network signal loss
    What model phone? what version Android? installed any new apps in the last few days?
    (edited)
    Sent by accident, not using the Android Central app
    Nexus 4 (Mako), Amaze 4G on T-Mobile. Nexus 7 16GB. Google Chromebook (2012 Samsung 16gb). Next stop, a Google flush toilet.
    Did I solve your problem? Hit the Thanks button. Was I just a nuisance? Sorry, can't bat .400 every day.
  3. #3
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Quote Originally Posted by ChromeJob View Post
    installed any new in the last few days?
    Yea, start backing out apps and see if that fixes the issue. Worst case, you can always do a factory reset. If that doesn't fix it, it could be a hardware problem.
  1. UI notification sounds - specifically signal loss/regain
    By funktron in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 06-30-2011, 01:43 PM
  2. Bad network signal? Try a new 4G sim card.
    By kxs783kms in forum Verizon HTC Thunderbolt
    Last Post: 03-30-2011, 12:46 PM
  3. Nexus one lost network signal please help
    By thejedimex in forum Google / HTC Nexus One
    Last Post: 10-02-2010, 08:10 PM
  4. Network Signal Notification?
    By namebrandon in forum Verizon Fascinate
    Last Post: 09-20-2010, 02:34 PM
  5. Force run EVO on Verizon network/signal
    By mikecpilot in forum HTC EVO 4G
    Last Post: 07-28-2010, 12:23 AM
