Results 1 to 4 of 4
    Default nexus 7 and android
    does anybody know why nexus is showing up twice in device manager ,as an android atb and as nexus digital camera, my computer only shows the digital camera?
  2. #2
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    Default Re: nexus 7 and android
    Do you mean Android ADB? If so, this is Android Debug Mode and is used for development purposes. The camera would be for accessing photos and what-not on internal memory. If you select the camera is should load the photos, right?
    thanks and yes you're right,but shouldn't it be listed as something other than a camera device other wise how else to transfer music, ,docs or whatever? I'm new at this but I thought it would bee listed as
    something other than that .before rooting it had different properties .pdp ,pda or something like that .any help appreciated
  4. #4
    srkmagnus's Avatar
    Posts
    ROM
    Yeah, the naming on the drive sometimes is not what you would think it should be. You may be able to change the name of the drive by right-clicking it via the computer and select the appropriate action.
    There's a lot of resources on this site to help you learn Android. Check out the forum for your device and don't hesitate to ask questions if you can't find the answer (after searching). Welcome to AC!
  1. New Nexus and android owner
    By crispyswinger1 in forum Google / Samsung Galaxy Nexus
    Last Post: 10-21-2012, 07:27 AM
  2. Dumb wallpaper question with Galaxy Nexus and android
    By daso in forum Wallpapers, Ringtones, and Themes
    Last Post: 01-17-2012, 03:34 PM
  3. Galaxy Nexus and Android 4.0 sync capability
    By BJB1 in forum Verizon Galaxy Nexus
    Last Post: 11-23-2011, 01:30 PM
  4. Importing Galaxy Nexus -- Charger and Android Market
    By nirvanayoda in forum Google / Samsung Galaxy Nexus
    Last Post: 11-19-2011, 07:54 PM
  5. Nexus One and Android 2.1 Bug Thread
    By Postal Dude in forum Google / HTC Nexus One
    Last Post: 05-24-2011, 06:57 AM
