Results 1 to 2 of 2
- 11-05-2012, 11:53 PM
Thread Author #1
HTC Design Wifi Issue -- Please Help.
Hey there everyone!!
I often found your forums to be quite informative when I was using my Samsung 4G (Galaxy S I), it had helped me a lot, well, before my touch screen took a dive .. then I had to get a new phone. I purchased an HTC Design back in May or June of this year, and I have not had many issues with the until pretty recently. First it started "over heating", and it would get so hot that I would have to turn it off for a while, next the screen (not the glass piece, but the little LCD thing) started to show signs of "wear", lines and things would show up when I would be on a call and have to use the keypad, or something as simple as viewing or sending a text. I would get little "hiccups" with the wifi; it would show that it was connected, but it wouldn't allow me to use GTalk or it would take too long to browse the internet. Now that my phone took a 10 ft dive to the floor in a fit of accidental acrobatics, everything else still works (mostly) except the wifi, save my screen responding a little slower than usual.
I guess the question is simply this: Is there a way to fix it with out dealing with Sprint (I don't carry phone insurance, I know it's not a smart decision) or should I just turn it and my poor old GS 1 in for some store credit and buy a new phone? If there is a way to fix it that doesn't involve dissembling the phone, that would be great, but if Ihave to take it apart, we can do that too.
Thanks so much! - 11-07-2012, 10:28 AM #2
Re: HTC Design Wifi Issue -- Please Help.
Next time you are having issues with heat, I'd contact your carrier right away and ask for a replacement. You could still try.
If that isn't an option, you could try a factory reset in hopes that some of your many issues could clear up.
As for taking the phone apart, I'll let someone else take that one, lol.
HTC One X (AT&T) Stock Rom Issue... Please Help
By mr.vladzki in forum HTC One XReplies: 2Last Post: 06-23-2012, 11:49 PM -
WIFI Issues PLEASE HELP
By jegordon23 in forum AT&T CaptivateReplies: 33Last Post: 12-22-2010, 07:32 AM -
Wifi issue, please help?
By shypnoi in forum General Help and How ToReplies: 8Last Post: 12-20-2010, 08:05 AM -
Text issue!!!! Please help
By jbg21 in forum HTC Droid ErisReplies: 5Last Post: 01-22-2010, 09:04 AM -
Weird Head Phone (mic) Icon Issue PLEASE HELP!!
By oracle646 in forum HTC Droid ErisReplies: 4Last Post: 12-30-2009, 07:03 PM
Reply
