Results 1 to 8 of 8
- 11-07-2012, 09:35 AM
Thread Author #1
Headphones that allow song skipping with Slacker Radio on an Android??
Yeah, I know.. pretty specific. As of yesterday I'm now the proud owner of a new Samsung Galaxy S3. I'm also an avid slacker Radio fan, but have found that my headphones now won't skip songs on that app as they did on my iPhone.
Any thoughts? I'd prefer not to spend too much.. I eat through headphones at an alarming rate.
Thanks!
Jay - 11-07-2012, 10:09 AM #2
- 11-07-2012, 11:30 AM
Thread Author #3
- 11-07-2012, 05:06 PM #4
- 11-07-2012, 05:46 PM
Thread Author #5
Re: Headphones that allow song skipping with Slacker Radio on an Android??
The "button"? Which one? The one on the headset just pauses and plays. No skipping regardless of how many times I hit the button.
I'm hoping the headset can accomadate this (some headset). When I'm on the train the last thing I need is to be fumbling with the phone while I'm listening to my musak!
Thoughts? - 11-08-2012, 08:41 AM #6
The buttons on the Samsung headphones don't work for Slacker to skip music. They also don't work for Pandora. However, double-tapping the "Play/Pause" button does skip songs on Google Music and most media players (AFAIK).
I know that's not much help. I assume it's something that Slacker and Pandora haven't coded into their apps. Maybe another headphone would work, but I don't have any suggestions. - 11-08-2012, 09:33 AM
Thread Author #7
- 11-08-2012, 09:59 AM #8
I use slacker a lot as well. These lg tone plus hbs 730 work for skipping songs. Although if you pause, it won't let you resume the same song. You can can press skip and does go to the next one though. They're not the cheapest, but I think they're great. There's also the older 700 model that are a little cheaper. Let me know if you have any other questions. Hope this helps.
http://www.amazon.com/gp/aw/d/B009A5...idcentral00-20
Sent from my Sammy GS3
Issue with unwanted vibrations on Codename Android 1.6.0
By nextass in forum Google / Samsung Galaxy NexusReplies: 1Last Post: 04-01-2012, 10:12 PM -
Music App that allows audio control with wired headset?
By garment69 in forum AT&T ATRIXReplies: 8Last Post: 05-05-2011, 08:56 PM -
problems with slacker radio on the tb
By twistedjustice81285 in forum Verizon HTC ThunderboltReplies: 18Last Post: 03-31-2011, 04:49 PM -
Odd behavior With Slacker Radio
By eheif in forum Sprint Epic 4GReplies: 2Last Post: 10-24-2010, 09:58 PM -
Is there any good music player for Android that allows me to sync with my PC?
By vitalyb in forum Android ApplicationsReplies: 3Last Post: 01-11-2010, 12:59 PM
Reply
I can pause without problem, just can't skip songs.
