Results 1 to 5 of 5
    Default Huawei WiFi problems
    Guys i have a tmobile move balance,actualy a Huawei u8600-1.I have a home router.First two weeks my Phone worked great on wifi,but now it can even connect.
    I go to settings-wireless conections..-wifi settings-and turn wifi on.But it is not even scanning it doesnt show any router,not Even a scanning message((Non of the wifi fix apps working
    Can you guys help me???
  2. #2
    bblaze's Avatar
    Android Powered Human
    Posts
    ROM
    Stock ROM / Rooted Kernel
    Default Re: Huawei WiFi problems
    Is this problem only with your router at home or does your phone not detect WiFi at all, anywhere? Have you flashed any custom ROMs on the phone? More info needed.
    ____________________________________________________________
    If I've helped, feel free to hit that "THANKS" button. It will make my day!
    Default
    Quote Originally Posted by bblaze View Post
    Tnx for a quick reply.My phone cant detect wifi at all!! My phone is non rooted no custom Roms
  4. #4
    bblaze's Avatar
    Posts
    ROM
    Quote Originally Posted by HeaveeensDoor View Post
    Is your phone still under warranty with either the manufacturer or the carrier? Sounds like the WiFi chip may have gone bad.
  5. #5
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Look under Manage Apps for anything related and try clearing Cache/Data. On my phone I found Network Location and was able to clear Data for it. Try this first.
    Before doing that you should try and do a factory reset, see if that fixes the problem. Even if you contact the carrier, that is going to be the first thing they tell you to do, so, you might as well do it yourself. But, if after a factory reset, you will need to hope you are under warranty, or, if not, that you have insurance. Otherwise, you are probably SOL.
  1. Huawei Blaze U8510 wifi problems
    By alexander 57 in forum General Help and How To
    Last Post: 07-12-2012, 08:40 AM
  2. Wifi problem.
    By joec32033 in forum Verizon Droid Incredible
    Last Post: 09-13-2010, 07:02 PM
  3. Nexus running 2.2 wifi problems!!!
    By rick2123 in forum Google / HTC Nexus One
    Last Post: 06-05-2010, 12:28 AM
  4. Droid WiFi Problems
    By jlgraham in forum Motorola Droid
    Last Post: 03-30-2010, 03:02 PM
  5. Wifi Problems on Eris
    By twizler3 in forum HTC Droid Eris
    Last Post: 12-10-2009, 06:54 PM
