Results 1 to 2 of 2
    Perseveranze's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default My phone won't connect to wifi... [IMPORTANT]
    Hey,
    I got a really bad problem. My Samsung GS3 won't connect to my Uni's wifi. It connects to every other wifi, except my Uni's. This is a problem because I'm on low Mobile Data allowance, and that's because I didn't know my phone wouldn't be able to connect to my Uni's wifi...
    And it's something wrong with mine (which is specifically a 4g/lte), since my friend has a Samsung GS3, and that connects fine.
    Anyways, I think it has something to do with the 802.1x EAP wifi's... when I try to connect, it just keeps saying connecting and sometimes ends up "Authorization error".
    Here's some screenshots;
    Would appreciate any possible solutions to try.
    Thanks.
  2. #2
    Cellmeister's Avatar
    Posts
    Global Posts
    327 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: My phone won't connect to wifi... [IMPORTANT]
    "Authorization error". = wrong settings, pass, etc as you know & can also be from corruption
    Here I will throw a few quick things at ya that you might of missed that may help:
    Try putting all settings on your WiFi (phone) to generic
    Can you connect to any other WiFi?
    Double check your pass
    Did you try rebooting the WiFi Router?
    Did you try deleting all other WiFi Accounts & rebooting?
    Did you try a battery pull to reset any corrupted data? (Do it anyways!)
    Then if it still does not work, copy your friends Samsung GS3 Wifi settings exactly to try it.
    BTW nice pics
    Hope that helps
  1. Phone won't connect to PC or MAC
    By bailcam in forum Verizon Droid Incredible
    Last Post: 10-20-2013, 12:30 PM
  2. phones won't connect to wi-fi
    By NicoleW78 in forum General Help and How To
    Last Post: 09-08-2013, 12:34 AM
  3. My pc won't connect to phone after downloading drivers
    By Joemarsico in forum Verizon Galaxy Nexus
    Last Post: 05-11-2012, 03:29 PM
  4. Phone won't connect to wifi or 3g network
    By palmer0700 in forum Samsung Replenish
    Last Post: 04-25-2012, 01:39 PM
  5. My MAC won't connect to EVO WiFi
    By Jenayalynn in forum HTC EVO 4G
    Last Post: 09-03-2010, 01:38 AM
