Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Va1ha11a
    Default Stuck in bootloop and not rooted, How to back up data?
    So, my phone is stuck in a bootloop. I can restore factory setting, but first i want to back up my data, specifically my text messages. They are very important. Is there a way i can do that ?
    the bad news is Im not rooted. now im trying to find ways to save data from my the phone before i do a factory reset. i hope im lucky. maybe you guys know how to do it.
    Thanks,
    btw its an Htc desire S
  2. #2
    Default Re: Stuck in bootloop and not rooted, How to back up data?
    use one of this
    Thanked by:
    Quote Originally Posted by still1 View Post
    use on of this
    Those are nice apps for sms backup. But im afraid its not that easy for me now, my phone is stuck in a bootloop
  4. #4
    Quote Originally Posted by runingwild View Post
    Thanks,
    You have to fix the "boot loop" in order to do any backups or anything else 1st, besides the reset....
    Did you search for the "boot loop" issue?
    Did you try a long battery pull like for an hour?
    Did you use DropBox to put anything on, if you did you can access it via PC or Mac
    FYI: Sometimes after a reset, using the same accounts the text/SMS messages may reappear for the latest ones.
    Hope that may help
    •» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
    •» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX
    Thanked by:
  5. #5
    srkmagnus's Avatar
    Posts
    ROM
    Calkulin 2.7/Desperado
    If you are in a boot-loop and didn't not backup or save data prior to that then you are at a loss. Do you know what may have caused the boot-loop? Did it start happening after downloading an app or other file?
    Whatever files were saved on the sd card (minus app data) will still be present. Log back into your Google account and if you originally selected "keep device backed-up with Google" then you should have apps start to install once you get the phone setup. Otherwise, you can log into the Play Store via computer and see a list of app downloads and push to your phone from there.
    Thanked by:
    Quote Originally Posted by Cellmeister View Post
    Hope that may help
    at this point i can only think of doing a factory reset to fix the bootloop issue. By doing this, it will most likely delete everything, (although you say there is small chance that they may reappear).
    so i was thinking that while its in a bootloop, perhaps there is a way to access the data (sms...) and save it. maybe using Adb? using recovery?
    Quote Originally Posted by srkmagnus View Post
    no, i didnt backup anything prior Thats a rare thing on me.
    Yes, the phone started giving problems after downloading some apps.
    i will try logging into my Google account and into Play store (well, its the HTC Market for me).
  8. #8
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    What did you do directly before getting into a bootloop?
    Quote Originally Posted by Va1ha11a View Post
    i was downloading apps from the Htc Market. the phone got stuck, so restarted it a couple of times. but then it just got stuck in a bootloop.
  10. #10
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Weird. Unfortunately I don't think there's anything you can do. If your pictures are on the sd card, than they won't be affected by the wipe, but if they're on the internal storage, I think you're out of luck. Sorry I couldn't help you more.
    runingwild likes this.
  11. Thread Author  Thread Author    #11
    ok thanks. I thought maybe i could use ADB and some commands to access the data... ?
  12. #12
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Actually, you may be right. Did you have usb debugging on before the boot-looping started?
    EDIT: I googled and couldn't find anything for you, but that doesn't mean it can't be done. Note that all of the guides I found were not specific to your device and they also required root access. I hope you have an easier time finding a guide than I did. Good Luck.
    Thanked by:
  13. #13
    srkmagnus's Avatar
    Posts
    ROM
    If he's bootlooping chances are that adb won't be recognized. Once you get the device back up and running be sure to keep it backed-up regularly or take the plunge and root so that you can perform a system wide backup and restore if needed.
    Thanked by:
  1. How to back up old phone SMS and transfer to new phone?
    By bailman in forum Verizon Galaxy S3
    Last Post: 05-15-2013, 09:25 AM
  2. Chrome – not rooted how to run?
    By Bakerboy2253 in forum Verizon HTC Thunderbolt
    Last Post: 11-02-2012, 09:06 AM
  3. I'm also stuck in bootloop and cannot access recovery - SOLVED
    By defdave in forum Virgin Mobile Optimus Slider
    Last Post: 10-06-2012, 01:43 PM
  4. How to back up and restore contacts?
    By pnoozi in forum Verizon HTC Thunderbolt
    Last Post: 10-09-2011, 12:53 PM
  5. how to back up user dictionary??
    By cheebahawk1 in forum General Help and How To
    Last Post: 06-26-2010, 08:30 AM
