- 11-07-2012, 10:03 PM
Thread Author #1
Help! My Galaxy Tab might be bricked
I have my daughter's galaxy tab that seems to be bricked. its a SPH-P100 (Sprint).
my son was fooling around with it and left it in the following state:ys the following:
Android system recovery <3e>
Enter: OK Key, Select : Vol Up / Vol Down
reboot system now
apply update from sdcard
wipe data/factory reset
wipe cache partition
_____________________________________________________________________
-- bootmode=7 from cmdline...
E:failed to mount /cache (No such file or directory)
E: Can't mount /cache/recovery/command
-- Wiping data...
Formatting /data...
E:format_volume: rfs format failed on /dev/block/mmcblk0p2
Formatting /dbdata...
E:format_volume: rfs format failed on /dev/block/stl10
Formatting /cache...
E:format_volume: rfs format failed on /dev/block/mmcblk0p1
Data wipe failed.
E:Can't mount /cache/recovery/recovery_kernel_log
E:copy_kernel_file :: Can't open /cache/recovery/recovery_kernel_log
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:failed to mount /cache (no such file or directory)
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
Can anyone help me to fix this? or is it just an electronic paperweight now? - 11-07-2012, 10:47 PM #2
Re: Help! My Galaxy Tab might be bricked
just use up/Down volume to select reboot system now.
and congrats all your data has been deleted. - 11-07-2012, 11:43 PM #3
I don't think the OP has the ability to select the reboot option. His post looks like a screen dump showing the aftermath of doing something bad in the recovery menu. Unfortunately, I don't have any good suggestions.
- 11-07-2012, 11:56 PM #4
- 11-08-2012, 09:21 AM #5
scratch135. If you have luck with this ^ method, don't forget to post this solution in the other thread we were working on, just in case someone stumbles across that one and not this one.
Galaxy Tab Might be bricked - Help Needed
- 11-08-2012, 07:36 PM
Thread Author #6
Still1 I think that everythis has been deleted except the samsung spash screen.
Fairclough, thank you for the link, I will check it out and hope it will solve my problem
Devinator I most definately will post a solution if I find one, thank you.
By scratch135 in forum Samsung Galaxy TabReplies: 7Last Post: 11-07-2012, 10:11 PM -
Help! My Galaxy Nexus Soft-Bricked after Bootloader Unlock
By Flyspook in forum Verizon Galaxy Nexus Rooting, ROMs, and HacksReplies: 27Last Post: 09-04-2012, 01:45 AM -
Please Help Me Not Hate My Galaxy Tab
By 3rdCoDef in forum Samsung Galaxy Tab 10-inchReplies: 31Last Post: 10-07-2011, 05:16 AM -
Help can't search forums using my galaxy tab.
By vrtualchik in forum Samsung Galaxy Tab 10-inchReplies: 3Last Post: 08-26-2011, 05:45 PM -
I like it, Now help me LOVE my galaxy tab
By grizzylemon in forum Samsung Galaxy TabReplies: 10Last Post: 05-12-2011, 04:58 PM
Reply
