Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By Devinator
    expat57's Avatar
    Posts
    Global Posts
    8 Global Posts
    Default Help upgrading from 2.2 to 2.3 or whatever Chinese phone PCD ARD-2100
    I really can use some help upgrading my android 2.1, this is a Chinese cell PCD Model ADR-2100 Ver 2.2 Baseband TFNCKNLYM -0640-197
    Kernel 2.632.9-perf-SVN4324 BUILDSRV@LXDEV#1
    BUILD adr2100-GT-V1.0.9-20110914
    This my first Android and Im getting old so if you young people can help me I will greatly appreciate it.
    I tried different methods without any results....phone is rooted
    Thanks for any help you can give me.
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    Default Re: Help upgrading from 2.2 to 2.3 or whatever Chinese phone PCD ARD-2100
    You are rooted, but, can't flash a ROM? Just trying to understand exactly where you are stuck.
    expat57 likes this.
    expat57's Avatar
    Posts
    Global Posts
    8 Global Posts
    Yes I'm rooted, I guess I don't know what ROM I can use for this cell.
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    If it's some random Chinese cell phone, I don't know if you are going to be able to find a ROM, maybe. Just google the model number and try and find one. I doubt CM is going to have one for it, but, you can check if you want. But, I dunno that I'd waste too much time looking for one.
    Why exactly do you want to flash a new ROM?
    expat57 likes this.
    expat57's Avatar
    Posts
    Global Posts
    8 Global Posts
    Thanks for your response. I want to flash b/c there are many apps Im not able to D/W "Incompatible device" The drivers that were installed are Mellon USB Device. What I want to do is upgrade my android from 2.1 to a higher version IF POSSIBLE. Thanks again.... Are there other options? or buy a real phone.
  6. #6
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    No problem.
    Can't really think of anything. I'm not the most experienced flasher out there, so, maybe some others will chime in with some advice.
    If not, yea, probably best to think about getting a more main stream phone. If it's just an app incompatibility thing, just get a more mainstream phone and you shouldn't have that issue, you wouldn't even need to flash.
    expat57 likes this.
    expat57's Avatar
    Posts
    Global Posts
    8 Global Posts
    Thanks Devinator Yeah best think is to buy a REAL phone, bought this one really cheap but I don't see a solution either, thanks again buddy
  8. #8
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    Global Posts
    4,376 Global Posts
    Carrier
    Stock/Stock/CM9
    No problem!! Stick that one in the drawer as a backup phone. Good luck!!
    expat57 likes this.
  1. Rooting Phone - Still able to upgrade from 2.1 to 2.2?
    By kid320 in forum Software Development and Hacking
    Last Post: 08-23-2010, 01:05 AM
  2. Replies: 6
    Last Post: 07-16-2010, 11:25 PM
  3. Upgrading from Palm Pre to EVO
    By brichter45 in forum HTC EVO 4G
    Last Post: 07-06-2010, 04:38 PM
  4. Saving pictures from a text to the phone
    By spizzo2386 in forum Motorola Droid
    Last Post: 04-08-2010, 05:30 PM
  5. Upgrading from 1.5 to 1.x
    By editor2b in forum General Help and How To
    Last Post: 10-23-2009, 04:26 AM
