I bought a SGH-T999 from someone that has been rooted, I don't know exactly what software they use, the problem that I have with it is it want go in 4G. how can I get it to go in 4G?
Printable View
Are you in an area that has 4G coverage?Quote:
Originally Posted by view2night [Only registered and activated users can see links. Click Here To Register...]
yes
Have you ever had a successful 4G connection?
Did you check under your data settings that you have 4G enabled?
no, I think that's why I think they sold it ! Could it be the esn is bad? I tried down loading 4G widgets that didn't work. Is there something else in the market that I can download ?
and yes I check under the data setting it was enabled
Is it stock ROM or custom? Maybe try flashing another ROM?
custom
Well, then, maybe you should try flashing another ROM.Quote:
Yeah, it's likely broken in the ROM. Flash the a stock-based rom, and than report back.
EDIT: [Only registered and activated users can see links. Click Here To Register...]
