Results 1 to 10 of 10
    Default No 4g signal
    I bought a SGH-T999 from someone that has been rooted, I don't know exactly what software they use, the problem that I have with it is it want go in 4G. how can I get it to go in 4G?
  2. #2
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Default Re: No 4g signal
    Quote Originally Posted by view2night View Post
    Are you in an area that has 4G coverage?
    yes
  4. #4
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Have you ever had a successful 4G connection?
    Did you check under your data settings that you have 4G enabled?
    no, I think that's why I think they sold it ! Could it be the esn is bad? I tried down loading 4G widgets that didn't work. Is there something else in the market that I can download ?
    and yes I check under the data setting it was enabled
  7. #7
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Is it stock ROM or custom? Maybe try flashing another ROM?
  8. Thread Author  Thread Author    #8
    custom
  9. #9
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    custom
    Well, then, maybe you should try flashing another ROM.
  10. #10
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    Yeah, it's likely broken in the ROM. Flash the a stock-based rom, and than report back.
    EDIT:
  1. htc evo 4g no 3g signal
    By fishbusa in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 03-06-2012, 05:33 PM
  2. Picked up a 4G Signal in Los Angeles!
    By MrLogan13 in forum Sprint
    Last Post: 10-28-2010, 01:03 AM
  3. No 4g Love in Phoenix :(
    By RTim3PO in forum Sprint
    Last Post: 05-28-2010, 11:29 PM
  4. Sprint evo(no 4g) or Incredible
    By fatcat87 in forum General Help and How To
    Last Post: 05-17-2010, 11:40 PM
  5. htc evo 4g no 3g signal
    By in forum HTC EVO 4G
    Last Post: 12-31-1969, 07:00 PM
