Results 1 to 3 of 3
- 11-10-2012, 07:18 AM
Thread Author #1
Problems with ClockWorkMod backup/restore
Hi all,
I am fairly new to Andriod but I've used ClockWorkMod on both a HTC Explorer and now my new Galaxy Note 10.1 so I am gaining experience. I had a scare today because I reset to factory to do a test and when I went to restore my backup it failed to restore /data. I tried several attempts with several different Clockworkmod backups. None of them solved the problem. I should have stopped there I suppose and just recreated my data :-) but no, I read somewhere on the web that the way to fix that was to switch back to stock recovery and redo the ClockworkMod install / rooting process. Not sure why that would have helped but I tried it. Afterwards I coped the ClockworkMod files down into the tablet (from my pc) and tried to restore - the system image failed to load and now my device would not boot. Fortunately I had an older backup on my extcard and was able to load that. But during this process I ended up with the following questions that some of your gurus might be able to answer. I apologize if you think I should google for all these on the web- I am finding a lot of incomplete and confusing information so please feel free to send me pointers, links and comments to this list of questions
1. Why did ClockWorkMod fail to install the /data portion correctly? Do other people run into this (apparently based on a google search) I want to really depend on CWM
2. Is there a way to get support for ClockWorkMod or provide feekback about this? I read somewhere that the paid version works better, is that true?
3. When I go to the ClockworkMod website and try to download ROM Manager it only seems to want to download it for my HTC device, does that matter?
4. What does the 'create update.zip' do compared to cwm backup and what is the best way to snapshot my tablet for later restore?
5. How can I find and download the STOCK rom for GT-N8013 (in case I need it)? I could not find it at the SamMobile firmware page or anywhere else
6. What else should I know about ensuring that I have a good system backup and the correct tools to save system images, install custom roms and get back to my previous system image?
What would be awesome would be a document describing CWM and Titaniaum backup (and any other tools) needed to do full mgmt.
Thanks in advance. - 11-10-2012, 10:35 AM #2
- 11-10-2012, 05:30 PM
Thread Author #3
Problems with Titanium Backup on Nook Color
By dgabbert24 in forum Barnes & Noble Nook ColorReplies: 2Last Post: 04-20-2011, 05:43 PM -
Problems with ClockworkMod Recovery
By TroytheITguy in forum Motorola Droid XReplies: 0Last Post: 04-10-2011, 07:09 PM -
Problem with Titanium Backup
By alex2010 in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 10Last Post: 02-08-2011, 09:00 AM -
Problem with titanium backup restore
By shadowpr in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 2Last Post: 07-10-2010, 12:15 PM -
By shadowpr in forum HTC EVO 4GReplies: 0Last Post: 07-10-2010, 10:20 AM
Reply
