How to Fix Wifi after upgrading S2 from 2.3Gb to 4.04 ICS
HI Friends,
I have upgraded my Samsung Galaxy S2 from 2.3 Gingerbread to 4.04ICS thru ODIN - (Build No. IMM76D.XWLPM). After upgrading my WIFI stopped working even though the signal is showing wifi is connected.
Please help and let me know how to correct this.
Re: How to Fix Wifi after upgrading S2 from 2.3Gb to 4.04 ICS
go to settings-->wifi
click on your wifi and click forget. then connect again.
Hey I have tried this..but its still not working. Infact the signal strength of WIfi is showing strong but u cant access anything...
Are you able to connect to any other Networks and have it work successfully? Give that a shot.
I'm assuming you have rebooted the phone. Maybe turn airplane mode on and off?
It was immediately after the update? There weren't any apps you might have installed that could be conflicting?
Worst case, you can't figure it out and factory reset.
