Results 1 to 23 of 23
    Default LG Optimus Elite - Issues with Wifi
    So I reset my phone and
    before that the wifi was working fine,
    but now,
    for some reason i get this loop of
    "Obtaining IP Address",
    "Disconnected",
    then does it again.
    Anyone have any ideas?
    Will thank <3
    Example. It Loads this then disconnects after a while and repeats.
    Whoop Whoop to all of my Family!
  2. #2
    Default Re: LG Optimus Elite - Issues with Wifi
    click on the wifi in settings and forget network and connect again
    Quote Originally Posted by still1 View Post
    Tried it. Didn't work :/
    Would really appreciate some help guys.
    Quote Originally Posted by Rune Arc View Post
    Bumppp
    BUMP
  8. Thread Author  Thread Author    #8
    bump....
    Another shameless self-bump...
  10. #10
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Have you tried connecting to another network? Could be a problem with your network. If you can't connect to another, at least you have ruled that out as the problem.
    Thanked by:
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by Devinator View Post
    Any one i go to does the same man. Look at the picture, I'm using my library's in that one.
  12. #12
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Still, from the picture all I can tell is that you are trying to connect to one. But, if you are saying that the problem is for multiple, well, then that answers the question.
    Did you try turning of whatever that WPS option is?
    Thanked by:
  13. Thread Author  Thread Author    #13
    The WPS is just the protected setup, so you have to go to the router and press the button on that and it syncs. It's not an on/ off type of thing.
  14. #14
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Well, if you can't connect to any WiFi, and, you have forgotten all the networks and tried again, I'd do a factory reset. If that doesn't work, hardware and you should exchange it under warranty.
    Sent from my Transformer Prime TF201 using Android Central Forums
    Thanked by:
  15. Thread Author  Thread Author    #15
    I did a factory reset, that's what caused this I'm pretty sure. and this is the second phone i've gone through already from warranty.
  16. #16
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Well, if that didn't fix it, and the second one has the problem as well, return it again. You can also try explaining to them that the issue keeps happening and politely, but assertively, tell them they should give you a different model.
    Thanked by:
  17. Thread Author  Thread Author    #17
    The first one was a different issue. it was bricked. This one its just the wifi.
  18. #18
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Well, still, get it replaced. Call customer service. They'll have you factory reset. When that doesn't fix the problem, they'll send you a new one. That one shouldn't have the problem, if it does, call back and ask for a new model.
    Thanked by:
  19. Thread Author  Thread Author    #19
    I'll think about it. until then I hope someone else has some sort of bypass or something
  20. #20
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    I find it unlikely since as you stated you have posted this on five forums. But, I do hope someone has an answer for you. If not, and you exchange it, make sure to come back and post a follow up. Good luck!!
    Thanked by:
  21. Thread Author  Thread Author    #21
    yeah thanks for the input. I'll thank you too if i decide.
  22. #22
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Lol. What, I don't deserve a button thanks for the six posts trying to help?
    Thanked by:
  23. #23
    I bought 2 of these phones, one connects to WiFi, the other will not. After much frustration with the same issue I finally figured it out. Turn off the Bluetooth first ( uncheck the box ). Then you will be able to connect to your WiFi. You can then go back and recheck the Bluetooth box. It worked for my phone
  1. Mobile ID Issue (LG Optimus Elite)
    By stavvie34 in forum LG Optimus Elite
    Last Post: 05-03-2013, 01:29 AM
  2. Lg optimus s issues with getting access to root
    By nightspell in forum LG Optimus S
    Last Post: 11-19-2011, 10:15 AM
  3. help! lg optimus v flashed with rodimus stuck at boot logo! what do i do?
    By Jerenater10 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 08-02-2011, 08:52 PM
  4. LG Optimus One compatibility with Optimus S
    By cordell in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 02-02-2011, 07:52 AM
  5. Issues with WiFi and Browser
    By paintdrinkingpete in forum HTC Droid Eris
    Last Post: 12-12-2009, 05:18 PM
