Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By Va1ha11a
  • 1 Post By mamawM
    fwellers's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Quick question about battery charger
    Hi, just picked up my first android, a Motorola Razr hd maxi. I've been using blackberry for many years.
    I have a car charger for my old blackberry 9900 bold. Its usb2, just like the charging port on the razor.
    Does that mean it will work just fine and be safe to use on the razr ?
    thanks !
    Floyd
  2. #2
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Drew's CMX/Stock/Stock
    Default Re: Quick question about battery charger
    If the usb will physically fit (Don't force it!) than yes it will work fine and be safe to use. The razr is a micro usb, and from googling so is the blackberry. It should work fine.
    sledge007 and fwellers like this.
  3. #3
    mamawM's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    xtrrom 4.6.5
    blackberry chargers are usually safe to use on android devices. but motorola devices can be very picky so keep a close watch on you phone when you use it for the first few times, make sure that it is working and that the phone is not overheating, etc. stay away from 3rd party chargers as there have been numerous reports of problems. and just a heads up, just because a charger fits doesn't mean it will work. i have one that ( i'm not sure which device it came with) will work and charge my husband's droid charge and his wifi zoom tablet but does not work on my droid bionic at all, my phone doesn't even recognize that a charger is plugged in.
    fwellers likes this.
  4. #4
    sledge007's Avatar
    Posts
    Global Posts
    6,917 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Wicked Sensations
    If you think about your charger as a water source, and your phone as a drain, the drain will only take so much water. It doesn't matter how much water you pour into the drain, whether it's you turning on the tap, or taking a 5 gallon pail and dumping it into the sink. The same is true for your battery, it will only draw, what it's capable of drawing.
  5. #5
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You need to check the output amperage of the charger. As long as it is equal to or greater than that of the factory charger you have, you should be fine. As have been said, don't worry if it's rated higher because the phone will only draw as much as it needs. If it's lower, then you will over work the charger and it may fail, as well as possibly not give enough power to run the phone and you'll see your battery drain while plugged in.
    I've heard that Motorolas can be finicky about non-OEM chargers, but I haven't had that problem with my Bionic and regular Razr.
    fwellers's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for all the informative replies !
    Very helpful. I know what to do now. Appreciate it !!
  1. Quick question about the seidio extended battery available....
    By oscar the grouch in forum AT&T Galaxy Note
    Last Post: 05-17-2012, 02:55 PM
  2. quick question about possible structural damage to battery
    By m a x i m u s in forum HTC EVO 4G
    Last Post: 06-25-2011, 01:16 AM
  3. Quick Question about Battery Thingy
    By zachnelson in forum Verizon HTC Thunderbolt
    Last Post: 04-09-2011, 04:41 PM
  4. Quick question about the Seidio 3500 mah battery
    By stanleyKowalski in forum EVO Accessories
    Last Post: 03-09-2011, 04:03 PM
