Results 1 to 3 of 3
    Default top half of screen is darker with blue color lines running down
    How do I fix it? Can I? Outside screen is fine.
    HTC thunderbolt
  2. #2
    Va1ha11a's Avatar
    Troll Headhunter
    Posts
    ROM
    Drew's CMX/Stock/Stock
    Default Re: top half of screen is darker with blue color lines running down
    I think this is a hardware issue, maybe water got inside the phone? If you're feeling adventurous, you could try replacing the screen ( . If not, I think you'll just have to buy a new phone or put up with it.
  3. #3
    Devinator's Avatar
    Sūpā Saiya-jin Fō
    Posts
    ROM
    Stock/Stock/CM9
    Yea, probably hardware. To be sure, you can factory reset.
    If that doesn't fix it, is it under warranty, or, at least insurance? If so, might be time for a new phone.
  1. Nexus 7 Side of Screen is Cut Off
    By albertmartino in forum Google Nexus 7 Tablet
    Last Post: 11-02-2012, 04:17 PM
  2. PiSlight pinm tint top part of screen ...
    By allenpaul1975 in forum Verizon Galaxy S3
    Last Post: 10-04-2012, 01:27 PM
  3. What's with that keyboard icon at the top left of the screen?
    By Misterb in forum Verizon Galaxy Nexus
    Last Post: 02-12-2012, 08:44 PM
  4. Shortcut to jump to top/bottom of screen/page?
    By Chrisy in forum General Help and How To
    Last Post: 04-12-2011, 08:49 AM
  5. Replies: 1
    Last Post: 06-08-2010, 05:32 PM
