Results 1 to 10 of 10
- 11-12-2012, 08:45 PM
Thread Author #1
Downgrading from 4.0.4?
Hey guys!
So I've had a Samsung Galaxy Gio GT-S5660 for a while but today a friend of mine told me I should upgrade it.
So he installed me some new software or something (I'm a total newb at this :/ ) and I'm lost.
I'd like to go back to my old version (2.3.6 from what I've seen I believe it is Gingerbread). I'm stuck in 4.0.4 ICS...
Could someone please help me? I've been searching for hours now...
Details:
CynagogenMod statistics
Model: GT-S5660
Android version 4.0.4
S5660XXKT7
build: IMM76L
Thanks a lot,
Simon. - 11-13-2012, 12:13 PM #2
Re: Downgrading from 4.0.4?
Why do you want to go back?
- 11-13-2012, 02:11 PM
Thread Author #3
Several reasons, first of all :I liked the old version, this one is too different from GB for me. :/
Second: it's kind of slow, seems my phone can't handle it that well.
Third: No USB Mass Storage device n_n"
- - - Updated - - -
Third: No USB Mass Storage device n_n" - 11-13-2012, 02:25 PM #4
Well, you might want to give it a little bit to sink in. You might like it as you get used to it.
Haved you rebooted yet? Sometimes it can take a couple of boots to run smoothly.
Also, you could try a factory reset.
Sent from my Transformer Prime TF201 using Android Central Forums
- 11-13-2012, 02:31 PM
Thread Author #5
I've already done a factory reset and I've booted the phone like a thousand times the past 12 hours, still slow as hell.
And I've just encountered that my Samsung Kies doesn't recognize my phone any more... u_u"
I know it is asking you to work but I really want to go back to 2.3.6
- 11-13-2012, 03:09 PM #6
Well, you are going to have to find a 2.3.6 ROM for your phone and flash it. Can check CM.
- 11-13-2012, 03:15 PM
Thread Author #7
- 11-13-2012, 03:24 PM #8
You'd have to find a 2.3.6 stock ROM for your phone. You can try googling for it. I have no idea where one would be.
- 11-13-2012, 03:30 PM
Thread Author #9
- 11-13-2012, 05:25 PM #10
downgrade from 2.3 to 2.2.1
By skaterboy13 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 6Last Post: 07-15-2012, 09:47 AM -
Downgrade from 2.3.3 GB to 2.2 Froyo?
By brian6121990 in forum Motorola Droid X2Replies: 2Last Post: 09-03-2011, 01:21 AM -
[ODIN] Stock Rooted ED1 (downgrade from ED2) [2011.05.18]
By wynalazca in forum Droid Charge Rooting, ROMs, and HacksReplies: 50Last Post: 06-26-2011, 12:16 AM -
Downgrading from Android 2.2.1 to 2.2
By Saffron in forum LG VortexReplies: 3Last Post: 02-12-2011, 10:03 PM -
Downgrading from DJ05/DL09 on fascinate
By Chris3D in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 64Last Post: 01-11-2011, 12:48 PM
Reply
