1. Rune Arc's Avatar
    So I reset my phone and
    before that the wifi was working fine,
    but now,
    for some reason i get this loop of
    "Obtaining IP Address",
    "Disconnected",
    then does it again.
    Anyone have any ideas?
    Will thank <3
    Example. It Loads this then disconnects after a while and repeats.
    11-13-2012 07:28 PM
  2. Rune Arc's Avatar
    BUMP!
    11-14-2012 03:45 PM
  3. B. Diddy's Avatar
    Are you able to reset the router? Unplug it and plug it back in again after about 10 seconds.
    Another thing to try is to forget the network, then reestablish the network connection on your phone.
    Sent from my DROID RAZR using Android Central Forums
    11-14-2012 03:59 PM
  4. Devinator's Avatar
    Why are you bumping this when you have another thread identical to this one with more posts in it? You bumped it the exact same time you responded to my post.
    LG Optimus Elite - Issues with Wifi
    11-15-2012 11:47 AM
  5. Rune Arc's Avatar
    Bumping because I still need help 3 days later! Thats WHY.
    11-15-2012 12:00 PM
  6. Devinator's Avatar
    That doesn't explain why you have two threads. And why you are bumping both. I have been trying to help you, but, you didn't respond to my last post.
    Sent from my Transformer Prime TF201 using Android Central Forums
    11-15-2012 12:19 PM
  7. Rune Arc's Avatar
    You have to understand. Without my wifi I can only get on here for a few minutes a day at the library.
    and I did respond.
    AND I actually have 5 different threads on different android forums asking for help with this. NO ONES given any useful help :/ I'm gettin flustered.
    11-15-2012 12:27 PM
  8. Devinator's Avatar
    You still shouldn't have two identical ones in the same subforum here and bump them both.
    Well, I hope you at least appreciate people trying, even if their suggestions don't lead to an answer. No one is getting paid to help you.
    11-15-2012 12:31 PM
  1. bricked lg optimus m+ need help
    By licia678 in forum LG Optimus M
    Last Post: 09-21-2012, 05:44 PM
  2. help where can i get roms for lg optimus elite vm
    By renteria00 in forum LG Optimus Elite
    Last Post: 09-17-2012, 07:50 AM
  3. Replies: 0
    Last Post: 10-11-2011, 10:18 PM
  4. lg optimus s root help really needed
    By jacobtoro in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 05-29-2011, 07:15 PM
  5. LG Optimus V need help with running games PLEASE!
    By coldcrush390 in forum Virgin Mobile Optimus V
    Last Post: 04-05-2011, 06:11 AM
