J Jared Grace New member Nov 14, 2012 1 0 0 Visit site Nov 14, 2012 #1 Every time I try to restore it to factory settings, it turns off, turns back on, and then freezes on the page with the Huawei logo
D Devinator Sūpā Saiya-jin Fō Jul 27, 2011 3,000 147 0 Visit site Nov 15, 2012 #2 Rooted? I assume you are trying to reset from the recovery menu and it's not working? If so, might just be easiest to get it replaced under warranty, assuming you are still under warranty, that is.
